+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Advanced Member level 1
    Points: 3,853, Level: 14
    Join Date
    Nov 2005
    Posts
    440
    Points
    3,853
    Level
    14
    negative power factor
    Could someone show me the relationship, if any, withing the following terms:
    Lagging/Leading Power Factor (PF)
    Lagging/Leading Reactive Power (Q)
    Positive/Negative Reactive Power (Q)
    Can I say that Lagging PF = Lagging Q = Positive Q?
    Thanks.
  2. #2
    Full Member level 4
    Points: 3,391, Level: 13
    smxx's Avatar
    Join Date
    Aug 2005
    iran(ahwaz)
    Posts
    194
    Points
    3,391
    Level
    13
    negative reactive power
    hi
    we have a traveling power (reactive) that it is saved in magnetic and electric fields .for a half of priod it saved in mag. field (L)and for next half priod is saved in elec. field (C). for a inductanc load (L) ,current is lagging from voltage .so we say a inductive load has lagging reactive power.for a Cap. load we say it has leading reactive power.
    Negative Reactive Power (Q) used for generation of Reactive Power and positve for consumption.
    http://Can I say that Lagging PF = L... = Positive Q?
    Do you mean PF=Q ??
    •   Alt10th January 2006, 08:12
      advertising
  3. #3
    Join Date
    Nov 2005
    Posts
    440
    Points
    3,853
    Level
    14
    leading pf
    Quote Originally Posted by smxx
    hi
    Do you mean PF=Q ??
    I mean "Lagging PF" = "Lagging Q" = "Positive Q", correct? Thanks.
    I'm confused. Any problem with the following statements:
    For a load of capacitor VAr is produced and considered negative or lagging as in Figure 3.10.
    A capacitive load on the other hand will be represented by R-jX as shown in Figure 3.12 and hence produces lagging VArs.
    Or, pls check my another thread here:
    http://www.edaboard.com/viewtopic.php?t=148522
    Please give me your advices.
    •   Alt10th January 2006, 09:30
      advertising
  4. #4
    Full Member level 4
    Points: 4,144, Level: 15
    Join Date
    Nov 2004
    USA
    Posts
    211
    Points
    4,144
    Level
    15
    negative vars
    hi
    Here is the understanding I have:
    Lagging power factor is where the current lags the voltage (current peak occurs after voltage peak). This occurs if the load is inductive. In this case, the load consumes VArs. The question is now, is this positive VArs or negative VArs. Regardless, you must supply VArs. Most people call this positive VArs or positive Q.
    Therefore:
    Lagging power factor <=> load consumes VArs <=> positive Q <=> inductive load
    (I'm using <=> to denote an implication and an inverse implication. Basically, this is an equality)
    Leading power factor is where the current leads the voltage (current peak occurs before voltage peak). This occurs if the load is capacitive. In this case, the load supplies VArs. Most people call this negative VArs or negative Q.
    Therefore:
    Leading power factor <=> load supplies VArs <=> negative Q <=> capacitive load
    Remember, that leading and lagging is always measured using the voltage (or real power, which is in phase of the voltage). Therefore, negative Q is lagging the voltage and positive Q is leading the voltage. Using the convention, you should rewrite your implication to be:
    Lagging PF = Leading Q = Positive Q
    Also,
    Leading PF = Lagging Q = Negative Q
    •   Alt11th January 2006, 04:12
      advertising
  5. #5
    Full Member level 4
    Join Date
    Nov 2004
    USA
    Posts
    211
    Points
    4,144
    Level
    15
    lagging vars
    Actually, thinking about this some more, when
    Lagging PF then the VArs are lagging the P. Therefore, your statement is correct, but your text appears to be using the convention I mentioned in the post above. The book is backwards and bizarre, it confused me too. Sorry, but
    Lagging PF = Lagging Q = Positive Q.
    Everything else I said above is correct. I never really think in terms of leading of lagging Q, but rather leading and lagging current and the consuming or supplying of VArs.
  6. #6
    Join Date
    Nov 2005
    Posts
    440
    Points
    3,853
    Level
    14
    pf lagging
    I agree with u. The author of the text used kind of convention that confuses reader. Thanks for your explanation.
    Quote Originally Posted by jonw0224
  7. #7
    Full Member level 4
    smxx's Avatar
    Join Date
    Aug 2005
    iran(ahwaz)
    Posts
    194
    Points
    3,391
    Level
    13
    pf leading lagging
    hi all
    PF is a number between -1 and 1
    and reactive power Q may have any value.
    I don't understand this
    pls tell me.
    for fully sine wave we have
    V=Vm cos(Θ) where Θ=ωt
    I=Im cos(Θ+Φ)
    S=V*I=Vm *Im cos(Θ)* cos(Θ+Φ)=˝ Vm *Im [cos(2Θ+Φ)+cos(Φ)]
    S=[Vrms*Irms *cos(Φ)]+[Vrms*Irms*cos(2Θ+Φ)]=P+Q
    Q=Vrms*Irms*cos(2Θ+Φ)
    so freq of reactive power is 2Θ
    Q=Vrms*Irms*cos(2Θ+Φ)=Vrms*Irms*[cos(2Θ)cos(Φ)-sin(2Θ)sin(Φ)]
    for a period mean values for term cos(2Θ)cos(Φ) is 0 and for sin(2Θ)sin(Φ) is sin(Φ)
    so the mean value for Q is :Qm=Vrms*Irms*sin(Φ)
    this value is the Amplitude of a sine wave only.
    for dynamic PFC we must design a filter to measuering real time reactive power .
    thanks all
  8. #8
    Join Date
    Nov 2005
    Posts
    440
    Points
    3,853
    Level
    14
    pf leading
    Hello,
    I thought cos(θ) = cos(-θ) ≡ "positive value". So, PF should be a number between 0 ~ 1. Pls correct me if I am wrong.
    Sorry for my post that confusing u. Actually I tried to ask as follows:
    Lagging PF ≡ Lagging Q ≡ Positive Q
    ... meaning if a device gives "lagging PF", can we say that the Q associated to the device is "lagging Q" and "positive Q"?
    Thanks.
    hi all
    pls tell me.
    I=Im cos(Θ+Φ)
    thanks all
    •   Alt12th January 2006, 18:20
      advertising
  9. #9
    Full Member level 4
    Join Date
    Nov 2004
    USA
    Posts
    211
    Points
    4,144
    Level
    15
    positive vars
    Yes, pf is never negative. But you designate a "leading" power factor or a "lagging" power factor.
    Maybe some people use a negative sign to denote leading?
    We've been using equal signs for a "reversable implication". Basically, we've been saying A = B to mean that
    A implies B and B implies A
    It's a logical equality not a numeric equality. Sorry for the confusion.
