How can i provide space b/w the bits of a binary string ?
mona_c
Junior Member level 1
help ....Verilog
Hello every one
well i need help regarding ..Verilog formats.... can any one tell...that..how can i provide space b/w the bits of a single binary string...e.g. 11000111 is a binary no. now i need the same no. but with spaces..like this...
1 1 0 0 0 1 1 1 or vice versa
can v do it using Verilog???
today i m adding one more ques to this one.... i m not able to read data..from the text file..into my test bench ..cany one tell me how to do that in verilog?
thanx
take care
Mona
help ....Verilog
Create array of bytes and write to it char codes
of ones = 31h
zeros = 30h
spaces=20h
help ....Verilog
Please describe more clearly what type variable you are trying to manipulate. Maybe show us your code example.
help ....Verilog
you would be try this "1_1_0_0_0_1_1_1". normally i wrote binary like this "8'b1010_0101".
Re: help ....Verilog
of ones = 31h
zeros = 30h
spaces=20h
can u pplzz elaborate what u wanna say
Added after 4 minutes:
no code is there....the thing is very clear..... see this no. 1100 now i want this no. to show as 1 1 0 0 ..i.e. spaces in b/w the bits of the binary no. i want to manipulate an array of this kind...now can v do this suing verilog or using matlab???
help ....Verilog
Actually, it's not very clear what you want to do.
dear...nothing is there..... see this string of binary bits ... 10101011 now i want to put spaces b/w the bits of this number so that it looks like
1 0 1 0 1 0 1 1
hope i m clear now
help ....Verilog
I'm trying to understand. You are typing this in a text editor? You are writing a Verilog module and you are entering a literal string?
-or-
You are watching the results of a simulation and see "101010011" get printed to the console or output file, and instead want to see "1 0 1 0 1 0 1 1"?
There are possibilities here. What context is the binary number in?
Hi
if u are using $display, use '\b' to get a blank space or ' to '\t' to get a tab.
Eg : $display("%b\b%b\b%b\b%b", array[0],array[1],array[2],array[3]);
This should give you like : 1 0 1 0 instead of 1010
If you want more space use \t instead of \b
For reading from a file to your testbench consider using $fread, $fscanf, $fgetc.
Hope this helps
Vivek:D
-or-
hi..
the later one is correct !!! & i need to write..this form into the text file..taking output from a verilog code
help ....Verilog
If it's the later one, then I think vivek has answered your question.
Hi
If u want to write this info into a file use $fdisplay. You should open a file for this like :
   reg [0:3] array;
   integer log_pointer;
   initial
     log_pointer = $fopen("file_name");
     $fdisplay (log_pointer,"data = %b\b%b\b%b\b%b", array[0],array[1],
                   array[2],array[3]);
   end
This will write your data to a file of the name you specify. log_pointer shall be the file pointer for the file you opened. It will increment automatically by one line for every $fdisplay.
If you need more such info about verilog HDL you can refer the book "Verilog HDL: A Guide to Digital Design and Synthesis" by Samir Palnitkar. The ebook is available in this forum. Pretty good for beginning with verilog.
Hope this helps
Vivek:D
vivek said:
Hi
   reg [0:3] array;
   initial
                   array[2],array[3]);
   end
Hope this helps
Vivek:D
Hi vivek
thanx for ur help..but dear..i m not getting the right result yet..see what i m getting when i applied ur code
data = xbxbxbx b xbxbxbx b xbxbxbx b xbxbxbx b xbxbxbx b xbxbxbx b xbxbxbx b xbxbxbx b
certainly not a desirable thing :cry:
If that's approximately what you want, then how about changing the $fdisplay statement slightly?
integer log_pointer, n;
initial begin
  for (n=0; n<16; n=n+1)
    $fdisplay (log_pointer,"data = %b %b %b %b", n[3], n[2], n[1], n[0]);
  $fclose(log_pointer);
end
data = 0 0 0 0
data = 0 0 0 1
data = 0 0 1 0
data = 0 0 1 1
data = 0 1 0 0
data = 0 1 0 1
data = 0 1 1 0
data = 0 1 1 1
data = 1 0 0 0
data = 1 0 0 1
data = 1 0 1 0
data = 1 0 1 1
data = 1 1 0 0
data = 1 1 0 1
data = 1 1 1 0
data = 1 1 1 1
    mona_c
initial begin
end[/code]
data = 0 0 0 0
data = 0 0 0 1
data = 0 0 1 0
data = 0 0 1 1
data = 0 1 0 0
data = 0 1 0 1
data = 0 1 1 0
data = 0 1 1 1
data = 1 0 0 0
data = 1 0 0 1
data = 1 0 1 0
data = 1 0 1 1
data = 1 1 0 0
data = 1 1 0 1
data = 1 1 1 0
data = 1 1 1 1
Hi echo47
well i have done my task...with the help of ur two codes....the things is choose the mid way of two :D yepp
that is how i did & all thanx to u 8)
here is the code
wire [31:0] out;
initial begin
  log_pointer = $fopen("format.txt");
		$monitor($realtime,,"ps %d %h %h %h %d ",in,clk,oe,reset,out);
  $fdisplay (log_pointer,"%b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b %b", out[31], out[30], out[29], out[28], out[27], out[26], out[25], out[24], out[23], out[22], out[21], out[20], out[19], out[18], out[17], out[16], out[15], out[14], out[13], out[12], out[11], out[10], out[9], out[8], out[7], out[6], out[5], out[4], out[3], out[2], out[1], out[0]);
	$finish;
 end
& i got the correct ans..thanx again ..
God Bless u
take care
bye for now
Mona
