+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 5
    Points: 1,314, Level: 8
    Join Date
    Nov 2005
    Posts
    9
    Points
    1,314
    Level
    8
    fifo timing
    I use SPARTANIII internal block ram as FIFO, but the timing can't satisfy my requirement, the detail is as below:
    I need 125Mhz speed, but the ram data out can only implement about 100Mhz, how can I improve the speed.
    thanks, ackqin
    Timing constraint: TS_lclk = PERIOD TIMEGRP "lclk" 7.5 ns HIGH 50%;
    20913 items analyzed, 63 timing errors detected. (63 setup errors, 0 hold errors)
    Minimum period is 9.989ns.
    Slack: -2.489ns (requirement - (data path - clock path skew + uncertainty))
    Source: xmt_scheduler/addq_fifo/addq_fifo/B8.B (RAM)
    Destination: xmt_scheduler/addq_fifo/addq_dout_6 (FF)
    Requirement: 7.500ns
    Data Path Delay: 9.970ns (Levels of Logic = 3)
    Clock Path Skew: -0.019ns
    Source Clock: lclk_BUFGP rising at 0.000ns
    Destination Clock: lclk_BUFGP rising at 7.500ns
    Clock Uncertainty: 0.000ns
    Timing Improvement Wizard
    Data Path: xmt_scheduler/addq_fifo/addq_fifo/B8.B to xmt_scheduler/addq_fifo/addq_dout_6
    Delay type Delay(ns) Logical Resource(s)
    Tbcko 2.394 xmt_scheduler/addq_fifo/addq_fifo/B8.B
    net (fanout=1) 3.044 xmt_scheduler/addq_fifo/addq_fifo/N942
    Tif5 0.796 xmt_scheduler/addq_fifo/addq_fifo/BU197
    xmt_scheduler/addq_fifo/addq_fifo/BU203
    net (fanout=1) 0.000 xmt_scheduler/addq_fifo/addq_fifo/N8868
    Tif6y 0.342 xmt_scheduler/addq_fifo/addq_fifo/BU216
    net (fanout=1) 0.358 xmt_scheduler/addq_fifo/addq_dout_<6>
    Tilo 0.551 xmt_scheduler/addq_fifo/_n0025<6>9
    net (fanout=1) 1.459 CHOICE1368
    Tsrck 1.026 xmt_scheduler/addq_fifo/addq_dout_6
    Total 9.970ns (5.109ns logic, 4.861ns route)
    (51.2% logic, 48.8% route)
    •   Alt5th January 2006, 02:27
      advertising
  2. #2
    Advanced Member level 5
    Points: 32,456, Level: 44
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    fifo timing
    If you tell us exactly which chip you are using, and show us your design, maybe someone can help you better.
    "Data Path Delay: 9.970ns (Levels of Logic = 3)" -- That seems slow for only three levels of logic. Maybe your layout has long sprawling routes.
    •   Alt5th January 2006, 05:03
      advertising
  3. #3
    Newbie level 5
    Join Date
    Nov 2005
    Posts
    9
    Points
    1,314
    Level
    8
    how can I improve FIFO timing?
    echo47, thanks.
    I use xc3s400 -4, I only use this fifo in FPGA, all the signal is in the fpga.
    This fifo saves my data, and I will read out when I need. so I want to know, but the data out speed of fifo can't satisfy my 125Mhz requirement, so I want to know is there any way can make the data quicker out from fifo.
    •   Alt5th January 2006, 06:05
      advertising
  4. #4
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    That FPGA can easily go 125 MHz, so there's probably an inefficiency somewhere in the FIFO design. That's all I can say without seeing the design.
    If you have coregen, try using it to make the FIFO. You may have better luck.
