Circuit works fine with landline but not a cell phone
nipun
Member level 2
need help
i soldered a circuit for dtmf to bcd convertor using CM8870.it works fine with landline telephone.i want to use it with a cellphone.it isnt working with cellphone.i cut the wire to speaker of handsfree of a mobile and connected to the input of ic.still its not working.i intend to use it as a remote control by calling the mobile with another mobile.plz help ,its urgent.
Re: need help
dear,
your cellphone should able to produnye DTMF signal caose otherwise it wont't work.
and signal from cellphone should connect to input of MT8870
regards
Re: need help
hi nipun,
Like e_eja said, I think u should enable the TONE mode for the keypad in the "PHONE settings" for ur mobile, and also set it to 'LONG' tone mode.
I think it should work, we regularly use it for reaching the help desk for automated service for our service providers, they use the same thing.. -:)
This should do it i guess..
Regards
Sam
Re: need help
today i tried again.but this time i called from another cell,then i received the call,then asked the caller to press any key .it worked perfectly fine.i dont wha twas the problem.at first i used to press the key of the same cell with keypad tone activated.well anyway it worked out fine.
