+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Newbie level 1
    Points: 1,251, Level: 8
    Join Date
    Jan 2006
    Posts
    Points
    1,251
    Level
    8
    atx schematic
    I need a schematic diagram of any atx pc motherboard.I need to specify the ps2 mouse schematic diagram.so that I can locate the problem easily.
    •   Alt2nd January 2006, 15:48
      advertising
  2. #2
    Advanced Member level 2
    Points: 7,347, Level: 20
    the_risk_master's Avatar
    Join Date
    Aug 2005
    UE+MIT, Philippines, (14°N , 120°E )
    Posts
    662
    Points
    7,347
    Level
    20
    atx motherboard schematic
    what is the problem that you are stating?
    PS/2 port related?
    1 members found this post helpful.
    •   Alt2nd January 2006, 15:56
      advertising
  3. #3
    Points: 12,348, Level: 26
    artem's Avatar
    Join Date
    May 2003
    Turkey
    Posts
    1,350
    Points
    12,348
    Level
    26
    schematic diagram motherboard
    •   Alt2nd January 2006, 16:54
      advertising
  4. #4
    Full Member level 6
    Points: 6,204, Level: 18
    sawwa7's Avatar
    Join Date
    Oct 2004
    Posts
    331
    Points
    6,204
    Level
    18
    atx motherboard diagram
    hi kwik
    happy new year :)
    here's a complete schematic for 8GPNXP DUO .. hope it'll be of some help
    regards
  5. #5
    Full Member level 6
    sawwa7's Avatar
    Join Date
    Oct 2004
    Posts
    331
    Points
    6,204
    Level
    18
    hi artem
    first of all , thanks for the good link and sorry for posting this schematic but i didn't see ur post while i was posting mine .. we do post at the same time :)
    regards
    •   Alt2nd January 2006, 17:25
      advertising
  6. #6
    Points: 881, Level: 6
    Join Date
    Apr 2008
    Posts
    7
    Points
    881
    Level
    motherboard schematics
    i have a question. i have Acer Aspire 5715Z with de MB. Can you tell from the picture what tipe of capacitors and what value are those? And what else is wrong with the board?
  7. #7
    Super Moderator
    Points: 239,640, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,520
    Points
    239,640
    Level
    100
    mainboard atx schematic on
    At best, the capacitance can be measured, if one of the two capacitors isn't shorted. You should be, aware, that more parts, e.g. the MOSFET switches can be damaged, too. The capacitor defect can be either a spontaneous event, at best with limited effect, or e.g. a result of an input overvoltage, most likely causing a far-reaching damage.
    In either case, you should have an original schematic of the main board's power supply function, or a least sketch a partial schematic on your own.
  8. #8
    Newbie level 2
    Points: 334, Level: 3
    Join Date
    Mar 2011
    Semarang, Indonesia
    Posts
    Points
    334
    Level
    Re: atx schematic
    Quote Originally Posted by kwik View Post
    Lê Quang Vinh – lqv77
    you should use Google Chrome to be translated from Vietnamese language to a language you understand
