microcontroller(80c51 based moving pattern display using LCD
swathigujjari
Newbie level 1
Re: microcontroller(80c51 based moving pattern display using
hello sir,
i swathi studying Btech 4 yr working on this project so i need relavent information abt the BLOCK DIAGRAM,components,hardware,software code ,applications.please reply me as soon as possible.
thanking you,
swathi
Added after 2 minutes:
hai swathi
i will try to help u out
go through the book
"customizing 8051 microcontroller"
What type of pattern you want to make? What LCD you're using?
hi...
you can check out www.8052.com for lcd inferfacing with 8051
and if u want to simulate the whole system... use proteus vsm from www.labcenter.co.uk
