+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 25
  1. #1
    Full Member level 1
    Points: 2,625, Level: 11
    Join Date
    Jan 2005
    Posts
    111
    Points
    2,625
    Level
    11
    how to measure inductance
    Can somebody tell which instruments are needed to measure the inductance and Q of a spiral inductor and active inductor? how to measure it?
    Thanks.
    Best regards,
    chunlee
    •   Alt23rd December 2005, 01:18
      advertising
  2. #2
    Advanced Member level 1
    Points: 6,805, Level: 19
    boy's Avatar
    Join Date
    Sep 2002
    Thailand
    Posts
    481
    Points
    6,805
    Level
    19
    measuring inductance
    you can use a network analyzer. You can determine the Q value from group delay obtained from the network analyzer.
    1 members found this post helpful.
  3. #3
    Advanced Member level 2
    Points: 7,347, Level: 20
    the_risk_master's Avatar
    Join Date
    Aug 2005
    UE+MIT, Philippines, (14°N , 120°E )
    Posts
    662
    Points
    7,347
    Level
    20
    how to measure inductance of coil
    latest technology of Fluke Instruments (the Digital Multi Meter that is)
    can measure capacitance, charges (in coulombs) and inductances
    Hey, I use Fluke!
  4. #4
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    inductor measurement
    One of the easiest ways of measuring L is to build an LC oscillator with known capacitance, measure frequency and calculate the inductance from the common LC-tank equation: ω=1/√LC --> L=1/ω²C, where ω=2Πf ..
    See circuit below ..
    Regards,
    IanP
    4 members found this post helpful.
  5. #5
    Junior Member level 1
    Points: 1,324, Level: 8
    Join Date
    Nov 2005
    Posts
    16
    Points
    1,324
    Level
    8
    measure inductance of a coil
    Q meter is mostly used for the measurement of inductance and Q of circuit
  6. #6
    Member level 4
    Points: 2,151, Level: 10
    ramy gad's Avatar
    Join Date
    Nov 2005
    Posts
    74
    Points
    2,151
    Level
    10
    how to measure inductance of a coil
    •   Alt24th December 2005, 00:10
      advertising
  7. #7
    Full Member level 1
    Join Date
    Jan 2005
    Posts
    111
    Points
    2,625
    Level
    11
    measure inductance
    hi boy,
    can u pls tell how to measure inductance and Q using network analyzer?
    or send me some document about it?
    Thanks.
  8. #8
    Points: 12,554, Level: 26
    ahmad_abdulghany's Avatar
    Join Date
    Apr 2005
    San Jose, California, USA
    Posts
    1,209
    Points
    12,554
    Level
    26
    measuring inductance of a coil
    You can build an easy microcontroller based L/C meter
    here is it..
    I hope it helped.
    Ahmad
    2 members found this post helpful.
  9. #9
    Junior Member level 2
    Points: 1,653, Level: 9
    Join Date
    Jan 2005
    Russia SPb
    Posts
    23
    Points
    1,653
    Level
    9
    inductance measurement method
    Quote Originally Posted by chunlee
    hi boy,
    Thanks.
    The NA is a rather expencive & very rare instrument. You'd better try some LC-Q meter which are much easier to find.
  10. #10
    Points: 5,146, Level: 16
    sergio mariotti's Avatar
    Join Date
    Dec 2003
    Italy
    Posts
    468
    Points
    5,146
    Level
    16
    how to measure inductor
    VNA may measure L (and or C) but it's poorly accurate, especially on the Q determination.
    Qmeter, when used in conjunction with Standard inductances is the most accurate instrument.
    Qmeter give L, Q, SRF.
    •   Alt28th December 2005, 22:16
      advertising
  11. #11
    Points: 25,958, Level: 39
    Join Date
    Nov 2001
    Earth
    Posts
    3,667
    Points
    25,958
    Level
    39
    measure inductance coil
    Quote Originally Posted by sergio mariotti
    Why did you comment so ? When you short circuit of an inductance, you'll get "very accurately" R and X so then to find inductance value and its associated Q factor are not difficult.
    Because in RF region, inductances and capacitances are not flat responded and in my opinion an inductance or capacitance should be measured at the frequency of operation (or closer to )
    But essentially, Q factor measurement equipments can not reach very high frequencies and their results are therefore not indicative.
  12. #12
    Full Member level 1
    Join Date
    Jan 2005
    Posts
    111
    Points
    2,625
    Level
    11
    how to measure an inductor
    hi everyone,
    I'm intend to measure my inductor on wafer at frequency around 2.4GHz. So i think the VNA is suitable for me. Can someone pls briefly tell me the procedure to characterize the inductor? (spiral and active inductor)
    Thanks.
  13. #13
    Join Date
    Dec 2003
    Italy
    Posts
    468
    Points
    5,146
    Level
    16
    fluke inductance meter
    Quote Originally Posted by BigBoss
    I try to answer BigBoss and chunlee both.
    The accuracy of VNA measurement is set mainly by Standards, that are usually very accurate jewels, and often the residual accuracy is of the order of +/-0.02...0.05 (number! not dB). But, when you try to measure very reactive devices (i.e. near to the boundry of the Smith Chart) , a small uncertainty like +/-0.02 , will became a large uncertainty on Q determination . I don't provide here the formulation, see Agilent AN-95.
    Qmeter has a different principle of operation. It read the resonant extravoltage.
    But if the practical measurement needs are on wafer, there is no choices. Both VNA and on-wafer Standards are required.
    Answering chunlee, set the VNA to display a Smith Chart on the screen. If necessary set marker parameters to display R+jX. I know that is possible on Agilent 87xx and 8510. Q=|X/R|
    Since the accuracy on-wafer will be not very high, my suggestion is that the user should propagate the uncertainty equation to give an evaluation of the instrumental uncertainty.
    Agilent provide a free and useful MS Excel speadsheet to evaluate uncertainty. look for "VNAUncert"
  14. #14
    Full Member level 3
    Points: 2,765, Level: 12
    Join Date
    Jan 2005
    Posts
    167
    Points
    2,765
    Level
    12
    measuring coil inductance
    What is the best way for measuring the inductance of a small planar coil inductor (i.e. RFID tag) ?
    Would it be OK to use the VNA method for this? i.e. connect both terminals of the coil to a 50 Ohm bnc connector and measure it that way?
    OR
    Is there a better suited method? i.e. involving a signal/function generator?
    Regards
    Cat
  15. #15
    Full Member level 4
    Points: 5,770, Level: 18
    Join Date
    Aug 2004
    Posts
    227
    Points
    5,770
    Level
    18
    measure coil inductance
    hi everyone,
    Thanks.
    After doing two ports S-parameter measurement, transform S-matrix into admittance (Y) matrix, you can calculate Q and L using:
    Q=-Im[Y(1,)]/Re[Y(1,1)]
    L=Im[1/Y(1,1)]/ω
    I am not sure whether there is difference between the calibration procedure of passive inductors and active inductors.
    Regards,
  16. #16
    Full Member level 2
    Points: 2,828, Level: 12
    Join Date
    Oct 2004
    Posts
    138
    Points
    2,828
    Level
    12
    find inductance
    Treat the inductance as a two-port network, and you can measure the s parameter,
    and you can deduce the L from the S parameters.
    Perhaps not accurate.
    •   Alt9th January 2006, 14:17
      advertising
  17. #17
    Full Member level 3
    Join Date
    Jan 2005
    Posts
    167
    Points
    2,765
    Level
    12
    s parameter inductance
    To measure the inductance of a coil is the following method reasonable?
    1. Connect coil to DC voltage supply and measure the current
    2. Calculate the DC resistance
    3. Connect coil to an AC voltage suuply with known voltage and frequency, measure the current.
    4. Calculate the Impedance
    5. Calculate Inductive Reactance using results from steps 2 and 4.
    6. Calculate the Inductance using the result from step 5.
    Would this be accurate?
    Regards
    Cat
  18. #18
    Newbie level 6
    Points: 2,748, Level: 12
    Join Date
    Jan 2005
    Posts
    12
    Points
    2,748
    Level
    12
    how to find inductance
    Hi all,
    I got a problem when re-draw S-parameters after de-embedding procedure.
    I used ADS to re-draw Smith chart of an on chip spiral inductor.
    - 1st, I used GSG probe tip to measure spiral (DUT) not very high frequency (50MHz --> 10GHz). Here I got S_measured values.
    - 2nd, I measured inductor test-fixture only (open standard). Here I got S-open values.
    Since I got the S-parameters data, I used ADS to convert S into Y data (S_measured ==> Y_measured & S_open ==> Y_open).
    Then, took: Y_mo = Y_measured - Y_open
    Finally, Y_mo data were reconverted into S-parameters and plotted in Smith chart.
    But in here, the Smith chart was not as I expected.
    Please take a look at 2 pictures following:
    Is there any body give me an advice? I really appreciate any your help.
    Thank in advanced! ^_^
  19. #19
    Member level 2
    Points: 1,716, Level: 9
    Join Date
    Oct 2005
    Posts
    44
    Points
    1,716
    Level
    9
    fluke inductance
    Can you connect the same to a connector directly-both ends of the inductor and measure S11 to find L?
  20. #20
    Newbie level 3
    Points: 1,550, Level: 8
    Join Date
    May 2004
    Posts
    Points
    1,550
    Level
    8
    coil inductance measurement
    The problem is lying at that you Ymo=Y_meas-Y_Open, after that, the Y you got still include 50 ohm (system impedance) in series. That is why it looks so strange.
    Hope it help!
    Laipi
