+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Full Member level 1
    Points: 2,318, Level: 11
    Join Date
    Dec 2005
    Posts
    99
    Points
    2,318
    Level
    11
    loading IeBindKeys.il for bindKey functionality in IC5033
    hello all
    i have a file with the desired bindkeys for Layout called IeBindKeys.il....and in the file it is written that i should type the command IeInitCommonBindKeys() inorder to set this file as my default...but it does not work?
    any ideas anyone
    •   Alt21st December 2005, 14:04
      advertising
  2. #2
    Advanced Member level 5
    Points: 26,445, Level: 39
    Join Date
    Nov 2001
    Turkey
    Posts
    3,771
    Points
    26,445
    Level
    39
    Re: loading IeBindKeys.il for bindKey functionality in IC503
    Quote Originally Posted by nijMcnij
    hello all
    any ideas anyone
    Make a .cdsinit file( hidden attribute, there is a sample file in Cadence directory ) and modify this by adding
    load command as mentioned below
    load(strcat(" ")
    and when you lunch cadence by typing icfb& ( or anything else ) it will read that "initialization" file and bindkeys definition will be as you wish.As well as, you can define other skill codes to initialize for other tools and purposes.
    .cdsinit file can be customized as site, user and project basis. There is hierarchy for that file, take care that hierarchy..
    GL
    1 members found this post helpful.
    •   Alt21st December 2005, 16:59
      advertising
  3. #3
    Full Member level 1
    Join Date
    Dec 2005
    Posts
    99
    Points
    2,318
    Level
    11
    BigBoss.....you ain't called "Big" for nothing.....:)
    thank you for the assistance
