A question to DC(set_input_delay and set_clock_latency)
Websterskimo
Newbie level 3
set_input_delay
hi
set_input_delay means delay that ideal source to input port delay and set_clock_latency means that we estimate postlayout clock tree latency.
My question is comming.What is the fllowing three command different(I think that first command is the same as third command, true?)
set_input_delay 1 [get_ports CLK]
set_clock_latency 1 [get_ports CLK]
set_clock_latency -source 1 [get_ports CLK]
thanks.
set_clock_latency
Hi Websterskimo,
As far as I know, set_input_delay is used to constrain datapath, I never see it apply to CLK :D
set_input_delay synopsys
it must apply to clk reference.
input_delay is related to clk edge.
first command Ur giving for input delay according to clk edge.
second command- Ur telling clock latency (arrivel of clock-notslew)at last(fariest) FF delay.
3rd command- Ur telling clock latency in source means first(neariest) FF delay.
i think u can understand from my definations
see u
set_input_delay -add_delay
hi websterskimo,
For better understanding, u can check in SOLD (Synopsys Online Doc).
set_input_delay
using the man command in dc:
dc_shell-t>man set_clock_latency
you can find that:
-source
Indicates that delay is to apply to
clock source latency. By default, delay
is applied to clock network latency.
that is the difference
set_input_delay -max
set_input_delay specifies the input arrival time of a signal in relation
to the clock. It is used at the input ports, to specify the time it takes for the
data to be stable after the clock edge. The timing specification of the
design usually contains this information, as the setup/hold time
requirements for input signals.
set_clock_latency command is used to define the estimated clock
insertion delay during synthesis. This is primarily used during the prelayout
synthesis and timing analysis. The estimated delay number is an
approximation of the delay produced by the clock tree network insertion
(done during the layout phase).
set_input_delay dc
the input delay of the first command is 2 related the source of the clk if you use the second command simultaneously. input_delay + clock_latency
