+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Full Member level 5
    Points: 4,017, Level: 14
    Join Date
    Oct 2005
    Posts
    295
    Points
    4,017
    Level
    14
    Problem with using icprog for PIC16F84A in XP after working in Windows 98
    hi
    i use pic 16f84a but i was workin on win98
    but when i used xp icprog doesnt program on it
    i searched on net and download a file .sys and change properties in misc to work on xp but there was no solution can any body help
    •   Alt20th December 2005, 10:59
      advertising
  2. #2
    Full Member level 4
    Points: 5,939, Level: 18
    Join Date
    Sep 2001
    France
    Posts
    214
    Points
    5,939
    Level
    18
    icprog
    You can download a NT/2000 patch for icprog on http://www.ic-prog.com/icprog_driver.zip
    But I'm not sure it works well.
    Otherwise you can download Propic2 XP, it seems work.
    CD
    •   Alt20th December 2005, 13:01
      advertising
  3. #3
    Full Member level 5
    Join Date
    Oct 2005
    Posts
    295
    Points
    4,017
    Level
    14
    ic prog for xp
    the file has no extension
    how can i use it
    •   Alt21st December 2005, 12:28
      advertising
  4. #4
    Full Member level 2
    Points: 3,558, Level: 14
    Join Date
    May 2001
    Posts
    136
    Points
    3,558
    Level
    14
    ic-prog.com
    On xp try o decrease the i/o speed
    bye
  5. #5
    Full Member level 5
    Join Date
    Oct 2005
    Posts
    295
    Points
    4,017
    Level
    14
    pic icprog
    i downloaded the file but it doesnt work
    i adjusted the delay but there isnt any thing happens
  6. #6
    Junior Member level 2
    Points: 1,504, Level: 8
    Join Date
    Apr 2005
    Posts
    23
    Points
    1,504
    Level
    8
    icp-rog
    What error message do you get?
    One thing that worked for me was clicking right click on the icprog icon and then choosing compatability and change and it the "run this program in..."
    choose win 2000.
    If this doesn't work there can be many other options depending on the error you get.
    Tzviel
    •   Alt29th December 2005, 15:19
      advertising
  7. #7
    Full Member level 2
    Join Date
    May 2001
    Posts
    136
    Points
    3,558
    Level
    14
    icprog pic
    maybe the problem can be due to the programmer, some programmers need more current from serial port and not all new pc are ok.
    Bye
  8. #8
    Full Member level 5
    Join Date
    Oct 2005
    Posts
    295
    Points
    4,017
    Level
    14
    www.ic-prog.com
    the program in this site is .sys file
    make a copy of this program in
    c:/windows/system32/drivers/
    then it will work good on xp
    but remmber to select the misc option xp
