+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 24
  1. #1
    Member level 3
    Points: 1,660, Level: 9
    Join Date
    Aug 2005
    india
    Posts
    56
    Points
    1,660
    Level
    9
    220v rms
    sorry for this silly question .but i can't find the answer anywhere..
  2. #2
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    220 v rms
    It is RMS ..
    If you would like to read more on this issue, here is a link:
    http://www.eng.uct.ac.za/~victor/electric/ACDC.htm
    Regards,
    IanP
  3. #3
    Member level 2
    Points: 1,507, Level: 8
    Join Date
    Jul 2005
    Posts
    44
    Points
    1,507
    Level
    8
    220v rms?
    It is in RMS... same as 110V in power lines
  4. #4
    Full Member level 3
    Points: 2,225, Level: 10
    Join Date
    Nov 2004
    Chennai, India
    Posts
    188
    Points
    2,225
    Level
    10
    110v vrms
    its RMS
    1 members found this post helpful.
    •   Alt16th December 2005, 12:42
      advertising
  5. #5
    Advanced Member level 2
    Points: 5,970, Level: 18
    Join Date
    Nov 2004
    Tamilnadu
    Posts
    657
    Points
    5,970
    Level
    18
    relation between rms and peak
    moreover .why it should be RMS ....why should not as +340V,-340V while referring
  6. #6
    Member level 4
    Points: 3,684, Level: 14
    Join Date
    Sep 2001
    Posts
    76
    Points
    3,684
    Level
    14
    relation between rms and peak voltage
    Quote Originally Posted by electronics_kumar
    because, simply said, this value (rms) is sort of a mean value which is engaged in, especially, power calculations, etc.
    e.g. for resistive loads power can be simply calculated multiplying current and voltage rms values: P = Vrms * Irms, whatever waveform it represents!
    (or P = Vrms*Vrms/Rload, or P = Irms*Irms*Rload, likewise with dc values)
    Referring to the peak value (only for sine waveforms!!!) power would be calculated:
    P = Vpeak * Ipeak / 2 (or P = Vrms*Vrms/(2*Rload), or P = Irms*Irms*Rload/2)
    It allows to compare or evaluate "power contents" of different waveforms in a way, while its peak values don't give any information as to this point.
    Best Regards
    Eric
    •   Alt16th December 2005, 14:59
      advertising
  7. #7
    Points: 7,347, Level: 20
    the_risk_master's Avatar
    Join Date
    Aug 2005
    UE+MIT, Philippines, (14N , 120E )
    Posts
    662
    Points
    7,347
    Level
    20
    rms 220v
    Try to grab a Digital Multimeter (select it as to measure AC voltage with range of at least higher on what you are expected to measure) Now read the Meter, it should read 220V (note all meter device should read RMS values)
    •   Alt16th December 2005, 16:46
      advertising
  8. #8
    Member level 4
    Join Date
    Sep 2001
    Posts
    76
    Points
    3,684
    Level
    14
    220 vrms
    Quote Originally Posted by the_risk_master
    To tell the truth the above is not always true. Multimeters usually display rms value but this fact does not mean they really measure it. If they do, you can see the notice "True RMS" somewhere on the device and such a device is also appropriately more expensive (it requires a built-in rms converter). Other devices usually measure peak or mean value of a rectified waveform and take advantage of the fact that the relations between peak/mean and rms (root mean square) values for a known waveform, in this case sine wave, are constants so that they can recalculate it and display. This fact implies that such a device displays the more inaccurate value (sometimes really nonsens) the more the measured waveform "differs" from sine wave.
    For instance waveforms in circuits with a phase controlled SCR (thyristor or triac) give quite big errors measured with non-true rms devices.
    Just for interest, the mentioned values are defined as follows:
    For periodic waveforms v(t):
    mean value =
    rms value = ,
    where T is the time period.
    Sine wave:
    If v(t) = Msin(ωt),
    where M ... peak value of the sine wave,
    ω = =&nbsp ... circular frequency, we obtain:
    mean value = 0
    if fully rectified, then
    mean value = = 0.637M ... relation between mean (fully rectified) and peak value
    rms value = = 0.707M ... relation between rms and peak value
    rms/mean (fully rect.) = = 0.707/0.637 = 1.11 ... relation between rms and mean value of fully rectified sine wave
    Best Regards
    Eric
  9. #9
    Full Member level 3
    Points: 3,314, Level: 13
    xjackal's Avatar
    Join Date
    Jan 2004
    Posts
    150
    Points
    3,314
    Level
    13
    sin rms peak
    Root Mean Square
  10. #10
    Member level 1
    Points: 1,484, Level: 8
    Join Date
    Dec 2005
    Posts
    39
    Points
    1,484
    Level
    8
    220 v peak to peak
    Quote Originally Posted by ysenthilece
    this value is its rms it means root mean square so we calculate power from this values of voltage and current directly
  11. #11
    Newbie level 1
    Points: 1,045, Level: 7
    Join Date
    Feb 2007
    Posts
    Points
    1,045
    Level
    7
    220 is rms.peak voltage is 1.4*220=308v
  12. #12
    Newbie level 3
    Points: 1,085, Level: 7
    Join Date
    Feb 2007
    Posts
    Points
    1,085
    Level
    7
    rms voltage 220v
    it is a RMS voltage
  13. #13
    Junior Member level 3
    Points: 1,152, Level: 7
    Join Date
    Jan 2007
    Posts
    30
    Points
    1,152
    Level
    7
    i rms i peak
    it is exaclty rms (root mean square) and it peak voltage is √2220 (v).
  14. #14
    Full Member level 4
    Points: 2,347, Level: 11
    Join Date
    Jan 2007
    India
    Posts
    195
    Points
    2,347
    Level
    11
    rms and peak to peak
    RMS VALUE
  15. #15
    Member level 4
    Join Date
    Sep 2001
    Posts
    76
    Points
    3,684
    Level
    14
    it(rms) scr calculation
    Are you collecting points or what?
    STOP these stupid messages, everybody already KNOWS it is rms!!!
  16. #16
    Full Member level 5
    Points: 1,993, Level: 10
    Join Date
    Feb 2007
    Posts
    241
    Points
    1,993
    Level
    10
    calculate 220 rms peak value
    if its a sine wave its rms value..
    if its a nonsinusoidal wave it wont be RMS...any way becoz every wave can be converted as composition of sine wave there is a true rms meter which gives rms for any wave..gen all ac and dc volts xpressed in rms ..
  17. #17
    Newbie level 6
    Points: 1,168, Level: 7
    Join Date
    Aug 2006
    Posts
    11
    Points
    1,168
    Level
    7
    310v sine rms
    It should be rms.
  18. #18
    Full Member level 1
    Points: 2,033, Level: 10
    Join Date
    Apr 2006
    India
    Posts
    114
    Points
    2,033
    Level
    10
    26 vrms vs peak
    Its RMS .Please check BL thereja u can get all the details.
  19. #19
    Advanced Member level 1
    Points: 5,617, Level: 17
    Join Date
    Feb 2002
    Italy
    Posts
    410
    Points
    5,617
    Level
    17
    220v rms peak
    It is RMS, the peak voltage is RMS * sqare root o f2, say about 310 V.
    The multimeters ( low price ) usually rectify the voltage ( taking the peak voltage ) and then they divide it by SQRT of 2.
    Mandi
  20. #20
    Points: 1,410, Level: 8
    asas's Avatar
    Join Date
    Feb 2007
    Portugal
    Posts
    7
    Points
    1,410
    Level
    8
    p=vrms*irms
    It's RMS!
    Low price multimeters aren't True RMS, but if the signal you are messuring it's a Sine Wave there's no problem!! If not, the values shown would not be correct.........
    •   Alt19th February 2007, 22:48
      advertising
