+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Newbie level 3
    Points: 1,267, Level: 8
    Join Date
    Dec 2005
    Posts
    Points
    1,267
    Level
    8
    difference between active and passive filters
    For designing the band pass butterworth filter of 500kHz bandwidth and fL=200KHz and fH=800KHz which one is better solution?
    •   Alt12th December 2005, 08:55
      advertising
  2. #2
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    Active filters use amplifying elements, especially op amps, with resistors and capacitors in their feedback loops, to synthesize the desired filter characteristics. Active filters can have high input impedance, low output impedance, and virtually any arbitrary gain.
    They are also usually easier to design than passive filters. Possibly their most important attribute is that they lack inductors, thereby reducing the problems
    associated with those components.
    "A Basic Introduction to Filters–Active, Passive, and Switched-Capacitor"
    http://www.swarthmore.edu/NatSci/ech...oToFilters.pdf
    Regards,
    IanP
  3. #3
    Full Member level 2
    Points: 1,731, Level: 9
    Join Date
    Sep 2005
    Posts
    129
    Points
    1,731
    Level
    9
    difference between passive and active filters
    if you can choose off chip method, that is better
    •   Alt12th December 2005, 10:38
      advertising
  4. #4
    Newbie level 3
    Join Date
    Dec 2005
    Posts
    Points
    1,267
    Level
    8
    active passive filters difference
    Thanks for reply,
    In my application ie for 200KHz to 800KHz which solution is better.
    Is active or passive?
  5. #5
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    For resons quoted in my previous post I would go for active filters..
    Regards,
    IanP
    •   Alt13th December 2005, 12:13
      advertising
  6. #6
    Newbie level 3
    Join Date
    Dec 2005
    Posts
    Points
    1,267
    Level
    8
    different between active and passive filter
    Thanks Ian,
    I am also going with active filter but while designing i found that with smaller Q factor the passband is less.
    since our application is of higher frequency i am not getting flat response.
    Can u suggest any artical which helps in selecting correct opamp for that.
    with thanks
  7. #7
    Points: 12,011, Level: 26
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    difference between active passive filters
    vasu,
    If you go the active route, the circuit must have considerable (i.e. >100) loop gain at the highest frequency of interest , in your case 800KHz. Otherwise the actual response will differ considerably from the ideal response.
    Some disadvantages of passive filters:
    Hard to design high Q inductors.
    Filter must be designed for specific source and load impedances.
    Regards,
    Kral
  8. #8
    Newbie level 1
    Points: 620, Level: 5
    Join Date
    Oct 2009
    malaysia
    Posts
    Points
    620
    Level
    Re: difference between active and passive filters
    what are the major diferences between passive and active filters used in the electronic instrumentation??can anyone please help me...
