Asynchronous Flip Flop Design?
electronicman
Member level 3
Hi
What ara the methodologies that we can use to design Asynchrous Flip Flop?
the design methodologies for synchrous Flip Flop are understandable and easy like
using FSM .....
Using the Asyn. reset method?
Why do you need to have an asynchronous flip-flop?
VHDL for
ENTITY flip_flop IS
PORT(
set : IN STD_LOGIC;
reset : IN STD_LOGIC;
data : IN STD_LOGIC;
clock : IN STD_LOGIC;
q : OUT STD_LOGIC;
nq : OUT STD_LOGIC
END flip_flop;
ARCHITECTURE beh OF flip_flop IS
SIGNAL qq : STD_LOGIC;
BEGIN
nq <= NOT qq;
q <= qq;
PROCESS(reset, set,data,clock)
BEGIN
IF reset = '1' THEN
qq <= '0'; -- asynchronous reset
ELSIF set = '1' THEN
qq <= '1'; -- asynchronous set
ELSIF clock'EVENT AND clock = '1' THEN
qq <= data;
END IF;
END PROCESS;
END beh;
Best regards :)
try searching for "sequential logic"
i assume u mean to make asynchronous counters or dividers....Use T-flip flops and external combinational logic to provide delays...look again whether u want synchronous or asynchronous...because in async case u will have to take a lot of care about delays
