Failed to open file in read mode.(modelsim)
Dylan01
Newbie level 5
failed to open readmem file
I want to read a data file and take the data in memory,
while using following
$readmemb("data.dat", memory); (memory is a register array)
modelsim giving following error
** Warning: (vsim-7) Failed to open readmem file "data.dat" in read mode.
and it is not reading the correct data.
Why this error is coming and what is the solution.contents of data.dat are :
@000
00010010
00000011
@002
11111111 01010101
00000000 10101010
@006
1111zzzz 00001111
someone plz suggest solution
failed to open readmem file in read mode
No problem here. I created data.dat and then ran this is ModelSim SE 6.1b:
module test;
  reg [7:0] memory [0:7];
  integer n;
  initial begin
    for (n=0; n<8; n=n+1)
      $display("%b", memory[n]);
  end
endmodule
Results:
# 00010010
# 00000011
# 11111111
# 01010101
# 00000000
# 10101010
# 1111zzzz
# 00001111
failed to open data file
this is the code . 1 thing here that code was working fine to me previously but now its not working . i wanted to know is there a problem in s/w shud i reinstall it ..
module readfile;
reg [7:0] memory[0:7];
integer i;
initial
begin
for(i=0; i < 8; i = i + 1)
$display("Memory [%0d] = %b", i, memory);
end
endmodule
failed to open readmem file in read mode.
Did the problem begin after you updated your ModelSim? Here are comments from various Release Notes:
Verilog Defects Repaired in 5.8e:
* A problem relating to $readmem resulted in memory leaks and large load times.
Verilog Defects Repaired in 6.0b:
* The system tasks $readmemh and $readmemb used to report an error when called with a memory that was either an automatic variable or a System Verilog class property
General Defects Repaired in 6.0e:
* $readmem for dynamic arrays did not work.
modelsim readmemb
i dont know what was the problem but after reinstalling it started working fine..
anyway thnks for ur help
modelsim file read and write
hi every body,
module test;
initial begin
end
endmodule
it not work, ...
please help me.
file data.dat :
@000
00010010
00000011
@002
11111111 01010101
00000000 10101010
@006
1111zzzz 00001111
Warning (10036): Verilog HDL or VHDL warning at test.v(2): object "memory" assigned a value but never read
Error (10054): Verilog HDL File I/O error at test.v(5): can't open Verilog Design File "data.hex"
Error: Can't elaborate top-level user hierarchy
Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 1 warning
Info: Allocated 134 megabytes of memory during processing
Error: Processing ended: Wed Apr 16 00:37:46 2008
Error: Elapsed time: 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 2 errors, 1 warning
Re: modelsim file read and write
module test;
integer n;
initial begin
//Path of the file which needs to be opened and read.
$readmemb("$NC_HOME/data.dat", memory);
end
endmodule
This problem is due to the fact that you didn't place the text file in your sim folder. Place the RAM file in the same directory from where you are running the simulation
