Use complex impedance port in MWO 2003 or above?
jackie1116
Junior Member level 2
Can i use complex impedance port (input ,output port) not real port(50 ohm) in MWO? I want to know ,whether the MWO can be used.
thank a lot!
I never used it myself but as far as I know it can be done. You can either enter a complex value in the port itself or enter a variable and then assign the variable a complex value.
you mean, MWO 2003 has complex port module .and that can input value,directly.
but i use MWO 2002 now,and i use portin module,but the resule is not accuracy.
