+ Post New Thread
Results 1 to 17 of 17
  1. #1
    Full Member level 3
    Points: 2,770, Level: 12
    Join Date
    Sep 2005
    Lions Den
    Posts
    173
    Points
    2,770
    Level
    12
    microcontroller 89c51
    Hi
    I am new to microcontroller, can anyone give me transmit & receive program to upload & download data between PC & 89c51 microcontroller.
    Thanks
    Centiago
  2. #2
    Member level 1
    Points: 2,078, Level: 10
    Join Date
    Feb 2005
    Posts
    36
    Points
    2,078
    Level
    10
    Maybe RS232 is the common way to solve your topic. And u can find the program anywhere.
    1 members found this post helpful.
  3. #3
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    how to interface microcontroller with pc
    If you can, I would ecourage you to build/buy a development board with RS-232 port ( http://www.pjrc.com/tech/8051/board3/schematic.html ) which includes some very usefull additional features such as for example SRAM ..
    Using a monitor program you will be able to upload/download contains of this SRAM, run programs dowloaded to SRAM and many more ..
    Check out this link:
    http://www.pjrc.com/tech/8051/paulmon2.html
    Regards,
    IanP
    •   Alt19th November 2005, 08:48
      advertising
  4. #4
    Member level 3
    Points: 1,635, Level: 9
    Join Date
    Mar 2005
    Posts
    59
    Points
    1,635
    Level
    9
    microcontroller to pc
    try first the parallel port instead of the serial just to get used to the interfacing as parallel is easier to understand and in assembly is easier to get data, serial is more complex in acquiring data as you have to wait that buffer is full and respond to the interrupt, more work
    enjoy
  5. #5
    Full Member level 4
    Points: 3,574, Level: 14
    Join Date
    May 2005
    Posts
    230
    Points
    3,574
    Level
    14
    interfacing microcontroller to pc
    •   Alt21st November 2005, 02:34
      advertising
  6. #6
    Junior Member level 3
    Points: 1,583, Level: 9
    Join Date
    Nov 2004
    Posts
    30
    Points
    1,583
    Level
    9
    interfacing of microcontroller with computer
    RS232 interface can generate interrupts and it needs few wires, but it will cost more because of a external RS232 level -shifter (such as max232) is needed.
    parallel port need almost no externel components, but it is diffcult to handle the realtime applications because of no interrupt will be generated if you use the parallel port.
  7. #7
    Points: 1,504, Level: 8
    Join Date
    Oct 2004
    Posts
    Points
    1,504
    Level
    8
    interfacing microcontroller pc
    Quote Originally Posted by khongai
    and there:
    h**p://chaokhun.kmitl.ac.th/~kswichit/
    www.8051.com
  8. #8
    Advanced Member level 3
    Points: 8,260, Level: 21
    Join Date
    Nov 2006
    Posts
    982
    Points
    8,260
    Level
    21
    microcontroller interfacing with pc
    not 51 8052.com
    •   Alt14th December 2006, 08:09
      advertising
  9. #9
    Full Member level 6
    Points: 4,497, Level: 15
    Join Date
    Mar 2006
    Trento, Italy
    Posts
    394
    Points
    4,497
    Level
    15
    interface 89c51 with pc
    hi,
    concern the following program and circuit
    ORG 30H
    INI:
    MOV TMOD,#21H
    MOV TH1,#0A0H ;9600 BAUD
    MOV SCON,#50H ;8 BIT UART MODE
    MOV TH0,#HIGH(-50000)
    MOV TL0,#LOW(-50000)
    SETB TR1
    MAIN:
    JB RI,SERIAL
    JMP MAIN
    SERIAL:
    CLR RI
    MOV A,SBUF
    JMP MAIN
  10. #10
    Member level 4
    Points: 1,546, Level: 8
    Join Date
    Jul 2006
    Karachi, Pakistan
    Posts
    68
    Points
    1,546
    Level
    8
    89c51 rs232
    Assalamo Allykum !
    You can do this by using parallel port as well as serial port.
    But asyou are new to Microcontroller then use Parallel port for your convenience, and usr At89C52 rather than AT89C51, because of memeory size because you are interfacing the data transfer from the PC.
    www.8052.com
    it is a good site and it will help you a lot.
    TAke CAre
    Wish you a good luck.
  11. #11
    Member level 1
    Points: 1,533, Level: 8
    Achievements:
    7 years registered
    Join Date
    Jul 2007
    Posts
    34
    Points
    1,533
    Level
    8
    microcontroller pc interface
    Can you define the commands in details since I know only the machine code. hex language
  12. #12
    Advanced Member level 1
    Points: 4,355, Level: 15
    Join Date
    Nov 2004
    Posts
    451
    Points
    4,355
    Level
    15
    which language are you planning to use on pc "C" or "VB" i'm having examples i can send it
  13. #13
    Full Member level 3
    Points: 2,949, Level: 12
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    India
    Posts
    172
    Points
    2,949
    Level
    12
    interfacing of 8051 with pc
    it is simple just put a mediator between 8051 and PC that is max232 IC and connect it to PC this will do the job
    •   Alt4th September 2007, 06:06
      advertising
  14. #14
    Newbie level 2
    Points: 949, Level: 6
    Join Date
    Sep 2007
    Posts
    Points
    949
    Level
    89c51 development board
    how to interface 89c51 microcontroller with computer keyboard?
  15. #15
    Full Member level 6
    Join Date
    Mar 2006
    Trento, Italy
    Posts
    394
    Points
    4,497
    Level
    15
    interfacing microcontroller with computer
    Assalam
    Akbar, better u ask this question in new topic ....
    because the ATKeybaord is working on I2C protocol having data clk Vcc GND lines
    please check the following website
    http://www.beyondlogic.org/keyboard/keybrd.htm
  16. #16
    Full Member level 3
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    India
    Posts
    172
    Points
    2,949
    Level
    12
    8051 interfacing with computer
    first try to understand at what protocal does the keyboard works then by using the 8051 core i think it is possible to communicate the micro controller with the computer keyboard
  17. #17
    Newbie level 3
    Points: 507, Level: 4
    Join Date
    Mar 2010
    Pune
    Posts
    Points
    507
    Level
    Re: How to interface 89c51 microcontroller with PC
    Can i get the "c" program of these.
