+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Full Member level 5
    Points: 6,203, Level: 18
    shaq's Avatar
    Join Date
    Jul 2005
    Posts
    312
    Points
    6,203
    Level
    18
    static cmos
    Hello everyone,
    How to compare static CMOS with dynamic logic from speed and power's view?
    •   Alt8th November 2005, 10:43
      advertising
  2. #2
    Full Member level 3
    Points: 2,436, Level: 11
    Join Date
    Aug 2005
    Posts
    173
    Points
    2,436
    Level
    11
    static cmos dynamic cmos
    what does dynamic logic means?
  3. #3
    Full Member level 5
    shaq's Avatar
    Join Date
    Jul 2005
    Posts
    312
    Points
    6,203
    Level
    18
    dynamic cmos logic
    Quote Originally Posted by anjali
    The output has floating point.
    Just like Dynamic CMOS logic,C2MOS, etc.
    •   Alt9th November 2005, 16:05
      advertising
  4. #4
    Advanced Member level 1
    Points: 5,152, Level: 17
    Join Date
    Jul 2004
    India
    Posts
    417
    Points
    5,152
    Level
    17
    static vs dynamic logic power
    dynamic CMOS logic - more or less like pseudo nmos/ generic logic. only dynamic power dissipation like pdyn= CL*Vdd^2.
    well static CMOS and Dynamic CMOS logics have their advantages and disadvantages.. if you go in for dynamic logic.. cascading is not possible as in evaluation stage the transition from 0-1 doesnt occur as PDN would be disabled. like u need to add an invertor to the dynamic cascaded CMOS to obtain domino logic.. this is how is it..static CMOS is also ok.. it has its own disadvantages..but static COS logic requires more transistors for implementing the logic.. somethin like N+2.. but in dynamic logic this is an attempt to reduce the number of transistors required to implement the logic.. somethin like N+1.
    correct me if i am wrong..
    with regards,
    arun
  5. #5
    Full Member level 4
    Points: 3,763, Level: 14
    Join Date
    Nov 2005
    Penang
    Posts
    216
    Points
    3,763
    Level
    14
    power consumption in static and dynamic logics
    The Complementary CMOS circuit design falls under two categories:
    1. Static
    2. Dynamic
    1.Static CMOS
    In Static CMOS design, at every point in time, each gate output is connected to either Vdd or Vss via a low-resistance path. Also, the outputs of the gate assume at all times the value of the Boolean function implemented by the circuit.
    A Static CMOS gate is a combination of two networks - the pull-up netowrk (PUN) and the pull-down network (PDN). The function of the PDN is to provide a connection between the output and Vdd anytime the output of the logic gate is supposed to be 1. Similarly, the PDN connects the output to Vss anytime the output is supposed to be 0.
    The PUN and PDN networks are constructed in a mutually exclusive manner such that one and only one of the networks is conducting in steady state.
    The Static CMOS gates have rail-to-rail swing , no static power dissipation. The speed of the static CMOS circuit depends on the transistor sizing and the various parasitics that are involved with it. The problem with this type of implementation is that for N fan-in gate 2N number of transistors are required, ie, more area required to implement logic. This has an impact on the capacitance and thus the speed of the gate.
    2. Dynamic CMOS
    Dynamic CMOS circuits rely on the temporary storage of signal values on the capacitance of high-impedance circuit nodes. These circuits also have no static power dissipation and uses a sequence of precharge and conditional evaluation phases with the addition of a clock input.
    The main advantages of the Dynamic CMOS logic are increased speed and reduced implementation area. Fewer devices are used to implement a given logic, this reduces the overall load capacitance and thus increases the speed.
    1 members found this post helpful.
  6. #6
    Full Member level 1
    Points: 1,707, Level: 9
    Join Date
    Jun 2005
    Posts
    97
    Points
    1,707
    Level
    9
    sizing of static cmos gates
    i think in modern digital technology, full-static CMOS is dominated,especially considering power consumption.
    dynamic CMOS is great in speed before 0.35um era,but now , static one is fast enough , because of large number of transistors in die ,power consumption became bottleneck, so dynamic CMOS is not popular anymore.
    •   Alt15th November 2005, 04:32
      advertising
  7. #7
    Member level 3
    Points: 1,612, Level: 9
    Join Date
    Mar 2005
    Posts
    56
    Points
    1,612
    Level
    9
    cmos domino logic
    For dynamic logic you also need to consider leakage, noise and clk skew related problems which become really hard problems in current deep submicron technology.
    Circuits robustness is alway more important than speed, especially in technologies below 90nm.
  8. #8
    Advanced Member level 2
    Points: 6,678, Level: 19
    gliss's Avatar
    Join Date
    Apr 2005
    Posts
    691
    Points
    6,678
    Level
    19
    dynamic logic advantages and disadvantages
    About Static vs Dynamic area. It is not always true that Dynamic is smaller. It depends on the logic fuction and implementation. For example, the Dynamic Inverter, 1 PMOS and 2 NMOS is larger than the Static Inverter, 1 PMOS and 1 NMOS.
    Also, it is correct that the Static implementation is more popular.
