+ Post New Thread
Results 1 to 13 of 13
  1. #1
    Member level 3
    Points: 1,660, Level: 9
    Join Date
    Aug 2005
    india
    Posts
    56
    Points
    1,660
    Level
    9
    difference between loop and mesh
    some books consider them to be the same ..but this question was asked in my exam.
    •   Alt29th October 2005, 17:50
      advertising
  2. #2
    Points: 12,011, Level: 26
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    difference between mesh and loop
    ysenthilece,
    They are the same thing. Node equations are the other main type equation used in network analysis.
    regards,
    Kral
  3. #3
    Member level 1
    Points: 1,830, Level: 9
    knmaheshy2k's Avatar
    Join Date
    Oct 2005
    Posts
    37
    Points
    1,830
    Level
    9
    mesh loop analysis
    hi,
    I agree with karl, basically loop can be defined as " The closed path formed by a number of circuit elements". This definition holds good even for "Mesh". So in "Network Analysis" both "Loop analysis" and "Mesh analysis" are the same.
    There is something called "Supermesh" which cannot be regarded as a "loop" or a "superloop".I hope this will clear ur doubt.
    Happy learning..............
  4. #4
    Newbie level 5
    Points: 1,994, Level: 10
    Join Date
    Aug 2005
    Posts
    10
    Points
    1,994
    Level
    10
    loop and mesh
    some said that loop may be consist of some meshes but mesh canot be consist of some loops
    this is an opinion i heard but in my opinion i think it is not
    they are the same
  5. #5
    Member level 1
    Points: 2,481, Level: 11
    Join Date
    Nov 2004
    Egypt, Benha
    Posts
    33
    Points
    2,481
    Level
    11
    mesh loop difference
    I tried to show the difference by drawing I think it is easier.
    the loop is a mesh but the mesh may be or may be not a loop.
    they two can be defined as " The closed path formed by a number of circuit elements"
    but in case of loop you may intersect with other elements.
    I hope the drawing explains it better.
    1 members found this post helpful.
    •   Alt29th October 2005, 21:34
      advertising
  6. #6
    Member level 3
    Points: 1,737, Level: 9
    Join Date
    Oct 2004
    Posts
    66
    Points
    1,737
    Level
    9
    difference between mesh and loop ?
    mesh consists of loops but loop doesnt consists meshes
    •   Alt3rd November 2005, 10:17
      advertising
  7. #7
    Member level 1
    Join Date
    Nov 2004
    Egypt, Benha
    Posts
    33
    Points
    2,481
    Level
    11
    what is the difference between mesh and loop>
    sorry funster and sabari I doubt your answers and you may refer to the link
    http://www.eas.asu.edu/~holbert/ece2...ipes.html#Mesh
    and the part of Loop or Mesh Analysis says that
    "Mesh (loop) analysis is generally best in the case of several current sources. In loop analysis, the unknowns are the loop currents. Mesh analysis means that we choose loops that have no loops inside them"
    that means "A mesh is a loop, but a loop is not necessarily a mesh"
    also at the slide 24 of the power point presentation in the following link
    http://download.intel.com/education/...ing/Lect12.ppt
    it says that:
    * A loop is any closed path through a circuit in which no node is encountered more than once.
    * To find a loop, start at a node in the circuit. From this node, travel along a path back to the same node ensuring that you do not encounter any node more than once.
    * A mesh is a loop that has no other loops inside of it.
    and the same words will be found in any circuit analysis book
    I hope I helped you.
  8. #8
    Member level 1
    Points: 1,665, Level: 9
    Join Date
    Oct 2005
    Posts
    41
    Points
    1,665
    Level
    9
    what are the differences between loop and mash.
    they are the same, loop and mesh there is no different between them, but the tearm loop have bigger meaning than mesh
    loop = # of mesh
    regards
  9. #9
    Newbie level 5
    Points: 1,316, Level: 8
    Join Date
    Oct 2005
    Posts
    10
    Points
    Level
    8
    difference between loop and mash.
    in brief,
    mesh is a loop with no other loops inside it.
  10. #10
    Junior Member level 1
    Points: 1,454, Level: 8
    Join Date
    Jul 2005
    IRAN
    Posts
    18
    Points
    1,454
    Level
    8
    difference between a mesh and a loop
    Every loop is a mesh but every mesh is not a loop.
    But you can have dependant loops in every circuit but not dependant mesh in every one( I mean the one that have the condition of solving with loop as you know we can solve every circuit with node method but not everyone with loop method their graph must have specific specification but i have not considered exceptions here)
    •   Alt23rd November 2005, 09:45
      advertising
  11. #11
    Junior Member level 3
    Points: 1,733, Level: 9
    Achievements:
    7 years registered
    Join Date
    Nov 2005
    pakistan
    Posts
    28
    Points
    1,733
    Level
    9
    difference between mesh loop
    check electronics by malvino.it will clear your concepts.
  12. #12
    Full Member level 5
    Points: 1,993, Level: 10
    Join Date
    Feb 2007
    Posts
    241
    Points
    1,993
    Level
    10
    what is difference between mesh and loop
    Loop and mesh r not same ofcourse..
    Mesh cant he any innermeshes r loops..but a loop can ve meshes inside it..
    This also just like circuit and a n/w..these r not same..
  13. #13
    Banned
    Points: 1,757, Level: 9
    Join Date
    Feb 2007
    Posts
    110
    Points
    1,757
    Level
    9
    difference between and loop and a node
    Added after 53 seconds:
    u also visit the web www.networksys.com
