How to simulate eye diagram in HSpice?
ilter
Member level 4
Dear all,
If I want to simulate eye diagram in hspice, how do I do?
Are there other tools simulating eye diagram?
If you have these information, can you help me?
Thanks.
eye diagram in hebrew
See the Orcad's app. notes page :
h**p://www.orcad.com/community.pspice.an.aspx
Replace * by t
eye diagram with hspice
lots of methods
1. use cssope for waveform viewer. It has a eye function
2. print the signal in hspice and plot its eye with matlab, before this you must write a matlab script first.
3. write a pwl source in hspice netlist such as
veye aaa 0 pwl (0 0 100n 100n r)
the 100n is the eye width,
after simulation completed, open the waveform by awave
and change the x-axis to v(aaa)
then polt the signal eye
matlab eye diagram plot hspice
flushrat said:
lots of methods
Dear flushrat,
I try (3) but I don't know 'r' means. Can you give me a example?
I simulate in hspice.
.PARAM width=1ns phase=0ns
.PROBE TRAN TIME2=par('TIME+phase-int((TIME+phase)/width)*width')
.tran 0.01n 10n
I use these. But I think these is wrong.
Can you tell me how to simulate eye diagram in hspice?
Thanks.
how to plot eye diagram in matlab
why don't you use MATLAB
you could move your output data to a matrix and import it to MATLAB, with a few lines of programming you could plot the eye diagram
example of plotting eye diagram matlab
excuse me sir
could you tell me more about a "few lines of programming you could plot the eye diagram"
thank you
eye diagram hspice
hi
use hspice toolbox.
Re: Eye diagram
In the calculator option of most of the tools I've found Eyediagram plotting option on which it will be plotted..I've found them in Cadence Virtuoso Analog Design environment and Mentor Graphics - System vision.
GD
Eye diagram
does hspice toolbox need additional license?
Re: Eye diagram
"why don't you use MATLAB
you could move your output data to a matrix and import it to MATLAB, with a few lines of programming you could plot the eye diagram"
hi! sir
could you give me a sample program regarding eye diagram?
thank you sir..
