Antonio_Magma
Full Member level 2
What is the significance of peak to peak voltage, as compared to normal peak voltage?
**broken link removed**Peak and Peak to Peak Value:
The maximum value, +ve or –ve of the alternating quantity is known as its peak value. It is also called maximum value or amplitude of the alternating quantity.
The total voltage measured from –ve peak to +ve peak is called the Peak to Peak voltage.
