how to write the below verilog code in vhdl
tarkyss
Full Member level 6
China
how to write aggregate in vhdl
b=a{1'b1};
a is a constant defined with 'define
b is std_logic_vector
for example
a=4
then
b=1111
I think this would work if a is a constant predefined in a package or something
signal b : std_logic_vector (a-1 downto 0);
for i in 0 to a-1 loop
b(i)<='1';
end loop;
hope it would help;-)
As mentioned above, you should use the constant a in the definition of b:
Then there is no need anymore to use a, you can just write:
b <= (others=>'1');
Look for "aggregate" in any good VHDL tutorial.
or simply
signal b : std_logic_vector(a-1 downto 0) := (others =>'1');
