+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 34
  1. #1
    Advanced Member level 1
    Points: 4,947, Level: 16
    Join Date
    May 2004
    oriental
    Posts
    494
    Points
    4,947
    Level
    16
    clock divider by 3
    Hi all,
    How to Build a Clock divider by 3 with 50% duty cycle?
    Input and output are listed below.
    Clkin
    __--__--__--__--__--__--
    Clkout
    ______------______------
    Any suggestions will be appreciated!
    Best regards,
    Davy
  2. #2
    Advanced Member level 2
    Points: 9,335, Level: 23
    Davood Amerion's Avatar
    Join Date
    Mar 2005
    Persia
    Posts
    584
    Points
    9,335
    Level
    23
    divide by 3 clock
    First you have to double input frequency, and then divide it by 3.
    then divide it by 2 to produce 50% duty.
    for doubling input frequency simply put one delay (such as RC, or buffer gates)
    for example 20nS, then XOR input frequency and delayed one, you get 2x multiplayer.
    Regards
    Davood Amerion
    4 members found this post helpful.
  3. #3
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    clock dividers made easy
    Below is a circuit that divides incomming wave by 3 with 50% duty cycle ..
    Reards,
    IanP
    5 members found this post helpful.
    •   Alt17th October 2005, 09:08
      advertising
  4. #4
    Full Member level 1
    Points: 1,707, Level: 9
    Join Date
    Jun 2005
    Posts
    97
    Points
    1,707
    Level
    9
    clock divide by 3
    I prefer Davood Amerion's method,
    that would avoid clock glitching.
    hi,IanP
    can you assure there is no glitching in your combinational source of clock?
    1 members found this post helpful.
  5. #5
    Points: 32,456, Level: 44
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    divider by 3
    It looks glitch-free. It's from a Xilinx app note "Unusual Clock Dividers":
    http://www.xilinx.com/xcell/xl33/xl33_30.pdf
    The author repeatedly warns about possible simulator problems, but I have no problem simulating it in Verilog/ModelSim.
    Both of these methods assume the input clock has 50% duty cycle, or else the output won't be symmetrical.
    2 members found this post helpful.
  6. #6
    Join Date
    May 2004
    oriental
    Posts
    494
    Points
    4,947
    Level
    16
    divide clock by 3
    Hi Davood,
    Thank you
    What's "and then divide it by 3." mean?
    Is it 50% duty?
    Best regards,
    Davy
  7. #7
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    divide by 3 circuit with 50 duty cycle
    The "divide it by 3" can be just an ordinary two-bit counter that goes 0,1,2,0,1,2,...
    After doing those steps, you would have signals like this. For the output to have 50% duty cycle, the input clock must also have 50% duty cycle.
  8. #8
    Full Member level 3
    Points: 2,436, Level: 11
    Join Date
    Aug 2005
    Posts
    173
    Points
    2,436
    Level
    11
    divide by 3 with 50 duty cycle
    Quote Originally Posted by Davood Amerion
    Regards
    Davood Amerion
    why dont we divide by 3 directly insted of multipliying by2, then divide by 3, and then divide by 2.
  9. #9
    Join Date
    Mar 2005
    Persia
    Posts
    584
    Points
    9,335
    Level
    23
    clock divided by 3
    Dear davyzhu,
    I think the echo47's answer is complete.
    Dear anjali
    Because when we directly divide by 3 we can't get 50% duty (insted we get 33.3% duty)
    Regards
  10. #10
    Full Member level 3
    Join Date
    Aug 2005
    Posts
    173
    Points
    2,436
    Level
    11
    clock divide 3
    hai davood, we can get 50% duty cycle even by directly DIVIDE BY 3. by using 2 couters (one posedge triggered & one negedge triggered) & once total count equals 3, output clk need to be toggled. i followed int his way, instead of multiplying by 2, then divide by 3, then divide by 2.
    •   Alt17th October 2005, 17:37
      advertising
  11. #11
    Join Date
    May 2004
    oriental
    Posts
    494
    Points
    4,947
    Level
    16
    divider 3
    Hi echo47,
    Why not go directly from "XOR" to "Divide by 6"?
    Best regards,
    Davy
  12. #12
    Full Member level 1
    Join Date
    Jun 2005
    Posts
    97
    Points
    1,707
    Level
    9
    unusual clock dividers
    oh, thanks to echo47 ,
    your design is glitching free,the combinational based latch is great!
  13. #13
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    clock dividers
    You guys are giving my too much credit. ;)
    I drew the timing diagram to illustrate the suggestion by Davood Amerion.
    The latch-based design was suggest by IanP. The design is from "Unusual Clock Dividers" by a Xilinx applications engineer.
    davyzhu, an ordinary divide-by-6 counter that goes 0,1,2,3,4,5,0,1,2,3,4,5,... wouldn't have 50% duty cycle. By separating the counter into divide-by-3 and divide-by-2, you get 50%. (Actually, this still is a divide-by-6 counter, but with a funny count sequence.)
    Someone asked me which program I used to draw that timing diagram. It's just lines drawn with a CAD program. I used good old OrCAD SDT for DOS. I still use it for large project schematics. I prefer it over all the modern tools.
  14. #14
    Advanced Member level 3
    Points: 9,432, Level: 23
    Join Date
    Jul 2004
    Posts
    892
    Points
    9,432
    Level
    23
    esnips + clock dividers made easy
    Here is one more ckt in verilog!!
    module clk_div3(clk,clk_out);
       input clk;
       output      clk_out;
       reg [1:0]   cnt_p, cnt_n;
       wire [1:0]   cnt_p_nx, cnt_n_nx;
       initial begin
          cnt_p = 2'b11;
          cnt_n = 2'b11;
       end
       assign clk_out = cnt_p[0] | cnt_n[0];
       assign cnt_p_nx = {cnt_p[0],~(cnt_p[0] | cnt_p[1])};
       assign cnt_n_nx = {cnt_n[0],~(cnt_n[0] | cnt_n[1])};
       always @(posedge clk)
         cnt_p <= cnt_p_nx;
       always @(negedge clk)
         cnt_n <= cnt_n_nx;
    endmodule // clk_div3
    You can add reset signal to remove the initial statement!
  15. #15
    Member level 4
    Points: 3,124, Level: 13
    Join Date
    Dec 2003
    India
    Posts
    78
    Points
    3,124
    Level
    13
    2/3 divider 50% duty
  16. #16
    Member level 5
    Points: 1,882, Level: 10
    maxsnail's Avatar
    Join Date
    Sep 2004
    Posts
    85
    Points
    1,882
    Level
    10
    verilog clock divider 50 duty cycle
    Thanks. it is useful for me
    Quote Originally Posted by nand_gates
       input clk;
       output      clk_out;
       initial begin
          cnt_p = 2'b11;
          cnt_n = 2'b11;
       end
         cnt_p <= cnt_p_nx;
         cnt_n <= cnt_n_nx;
  17. #17
    Full Member level 6
    Points: 7,678, Level: 20
    Join Date
    Jan 2002
    Posts
    336
    Points
    7,678
    Level
    20
    clock divided by 3 circuit
    Check this paper as well
    http://www.edaboard.com/ftopic101951.html
    Maybe it is the same as the one by tut.
  18. #18
    Junior Member level 3
    Points: 1,951, Level: 10
    Join Date
    Jan 2003
    Posts
    28
    Points
    1,951
    Level
    10
    xilinx application note digital clock divider
    If simplicity of design strikes you, then here's a solution.
    If i have a 3 bit ring counter preloaded with a value 001, then I tap the output from any point, I'd have a divide-by-three 33% duty cycle output.
    If i have another 3 bit-ring counter preloaded with same value 001, but clocked on the negative edge of the clock, I'd have another divide-by-three 33% duty cycle output with phase shift of 90 degree wrt the first output.
    I OR these two outputs and I get a divide-by-three 50% duty cycle output. Am i right?
    •   Alt30th December 2005, 09:13
      advertising
  19. #19
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    clock dividers made easy.pdf
    Yes that would give a 50% duty cycle (assuming the input clock is square), however I wouldn't say a six-flop solution is "simplicity of design". ;)
    By the way, if those two counters should ever fall out of sync (for example by a noise glitch or cosmic ray hit), then they would stay that way forever. I recommend using self-synchronizing logic wherever possible.
  20. #20
    Join Date
    Jan 2003
    Posts
    28
    Points
    1,951
    Level
    10
    clk divider 3
    Just so that i understand the comment. Is Davood Amerion's solution the best available? Aren't there any issues in that circuit to produce 2x frequency square waves from a XOR gate and delay elements? Isn't designing the delay element more involved than putting six standard flops? I ask this so that i get the perspective...
