Anybody has some idea about "guard rings"?
congqingzm,
On a printed wiring board, a guard ring is a trace that surrounds a sensitive via or device pin. It is used to intercept leakage currents, or to reduce capacitive coupling.
In semiconductors, N type material tends to accumulate holes on the interface between th N type material and the silcon dioxide passivation. A guard ring connected to ground or a negative voltage tends to sweep away the holes, thus preventing the N type material from becoming P type material on its surface. To the best of my knowledge, virtually all PNP transistors use guard rings. The use of a guard ring int the manufacture of PNP transistors was introduced by Motorola Semiconductor in the early 60's. This was a major breakthrough in increasing the yield of PNP transistors.
Regards,
Kral
Mention of IC design, the guard ring has two function, one is preventing noise cross and another is preventing latch-up.
