Thank you Lupin
The conformal antenna that I am trying to simlate with HFSS is a square p.a.t.c.h antenna resonating at 7.55 GHz.
How can I draw a conformal box ?
You know, I am new in using HFSS.
Although, I have simulate a planar p.a.t.c.h antenna that resonate at 7.55 GHz.
And, I would like to transform this antenna into a conformal one, but with the same dimensions. I don't know how to do.
I send you the figure of the planar antenna that I have simulate.
Is it enough for you ?
I think u need to build the structure up "ex novo".. I don't think there are dedicated commands to turn your structure into a conformal one .. U have to identify a surface (for example your gp), then selcting this u can build up the rest of the layers... I would proceed in this way....
What I want to underline is that the mesh must fit your structure.. do u have experience in CST.. ? In that code it's possible to have a preliminar view of the mesh.. for conformal antennas it's important to check very much.. what relation is between the mesh and structure dimensions....so your file are not sufficient for a mesh check...
I also have a problem...I think it's easier than yours...
I am not skilled on HFSS design implementatio..I know only theorical considerations for e.m. codes...
I have been mostly designing using only Ensemble (every version)... Now I have to use necessary HFSS and I'm quite in a hurry...
Then the HFSS help doesn't work.. I don't know why...
What I have to do is an easy project: a monolayer patch fed by a probe.
I report the dimensions ..
layer: Fr4
Finite ground plane 4 cm x 4 cm
substrate: FR4
height : 2.4 mm
patch dimensions 10 mm x 10mm
probe location (considering the center of the patch as reference): 5 , 0
I really need a step sy step procedure to implement the structure and to run the simulation.For example (how can I create a patch? a layer structure?a probe connecting the ground plane and the patch? how can I set the mesh?...? )
Please help me.
If u need my support in microstrip antennas, arrays, components..please ask.I'll be glad to give the courtesy back.
Hi Lupin
I found a document in this forum to simulate a p.a.t.c.h antenna with HFSS step by step. I send it to you.
I can't send you the project because its extensin(.hfss) is not allowed here.
I you succeed in transforming this antenna in a conformal one,please tell me. I am also in hurry.
