+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Advanced Member level 1
    Points: 4,136, Level: 15
    Join Date
    May 2004
    Posts
    423
    Points
    4,136
    Level
    15
    stacking voltage regulator to get more amperage
    Is it possible to get more amperage by connecting two same voltage regulator chip
    http://pdfserv.maxim-ic.com/en/ds/MAX603-MAX604.pdf
    in parrallel?
    •   Alt29th September 2005, 09:19
      advertising
  2. #2
    Full Member level 4
    Points: 3,574, Level: 14
    Join Date
    May 2005
    Posts
    230
    Points
    3,574
    Level
    14
    Re: stacking voltage regulator to get more amperage
    may be, but not recomended
    and at output of each regular chip use with resistor , e.g : 0.1 / 1 Ohm
    •   Alt29th September 2005, 10:29
      advertising
  3. #3
    Full Member level 1
    Points: 2,410, Level: 11
    Join Date
    Jun 2005
    India/Japan
    Posts
    112
    Points
    2,410
    Level
    11
    Amperage can be increased by connecting parallel transistors
    http://www.mitedu.freeserve.co.uk/Ci...er/1230psu.htm
    •   Alt29th September 2005, 12:41
      advertising
  4. #4
    Join Date
    May 2004
    Posts
    423
    Points
    4,136
    Level
    15
    is there a draw back to the circuit b/c it seems really simple and good.
  5. #5
    Full Member level 1
    Join Date
    Jun 2005
    India/Japan
    Posts
    112
    Points
    2,410
    Level
    11
    Well I didnt used the circuit the same circuit but have used the same principle to increase the amperage (only one transistor) of one of my circuit when I was in college and it just worked fine for me.
    I guess this is a well Known method of increase the amperage for power supply
  6. #6
    Newbie level 6
    Points: 1,381, Level: 8
    Join Date
    Jul 2005
    Posts
    12
    Points
    1,381
    Level
    8
    Yes, most regulator datatsheets show similar circuits. They work well.
  7. #7
    Junior Member level 3
    Points: 1,521, Level: 8
    timer's Avatar
    Join Date
    Aug 2005
    Posts
    30
    Points
    1,521
    Level
    8
    the only drawback would be that the regulator is a linear regulator. hence if you draw too much current and drop too much voltage across the regulator, you would be dissipating lot of heat. you can use a switching regulator instead (smps of an old comp.)
    •   Alt2nd October 2005, 16:05
      advertising
  8. #8
    Points: 4,904, Level: 16
    Join Date
    Mar 2002
    Posts
    447
    Points
    4,904
    Level
    16
    the problem would be mismatch - if one device was 2mv high, and the next was 2mv low, first device would drive all the power while the second was off.
    that was khongai's suggestion - a small ballast resistor drops some voltage dependent on load that tends to even out the mismatch.
    in general i would suggest against paralleling these, but with ballasting you could probably get away with it.
