The difference between reed relay and electromagnetic relay
breneer
Member level 2
Reed relay or Relay
What is the difference between reed relay and the electro magnetic Relay?
I will used it on 9v or lower and it will drive a 12V circuit.
Re: Reed relay or Relay
It is in the construction. The reed type is small diameter and very long. It has more of a constant impedance and can switch higher frequencies without degrading them.
Reed relays consist of a coil surrounding a reed switch. Reed switches are normally operated with a magnet, but in a reed relay current flows through the coil to create a magnetic field and close the reed switch.
For more info go to:
http://www.kpsec.freeuk.com/components/relay.htm
Regards,
IanP
