Synthesis Warning:same net is connected to more than one pin
lizeer
Newbie level 5
dc report there are same net is connected to more than one pin.
will it introduce any problem?
Re: Synthesis Warning:same net is connected to more than one
It may or may not cause problems depending on what pin it is. Even Reset can be a multidriven net. So check it out before going to layout.
It may lead to assign statements in your final netlist which some back-end tools will not accept.
This post: shows how to fix that problem.
You can also get ruid of this by flattening/ungrouping the design
