+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 30
  1. #1
    Member level 3
    Points: 1,690, Level: 9
    Join Date
    May 2005
    Posts
    57
    Points
    1,690
    Level
    9
    spi vhdl
    how to realize a SPI interface with VHDL?
    I find it is too difficult for a newbie. need your help .
  2. #2
    Full Member level 4
    Points: 3,339, Level: 13
    Black Jack's Avatar
    Join Date
    Dec 2003
    UKRAINE
    Posts
    236
    Points
    3,339
    Level
    13
    vhdl spi
    Quote Originally Posted by ymq8328
    see www.opencores.org
  3. #3
    Member level 3
    Join Date
    May 2005
    Posts
    57
    Points
    1,690
    Level
    9
    spi slave vhdl
    but it is realize in verilog, not in vhdl
    1 members found this post helpful.
  4. #4
    Full Member level 3
    Points: 3,249, Level: 13
    Join Date
    Jun 2001
    Posts
    187
    Points
    3,249
    Level
    13
    spi interface vhdl
    There Are Lots Of SPI Deratives. The Best Thing To Do, Is To Examine The Datasheets Of The Device You Are Interfacing, For The Required SPI Format.
    VHDL Is Not C, So You Should Always Write Your Own Code.
    SPI Is Very Simple - There Is Master And Slaves, So No Arbitration Is Needed,
    Also There Is One Receive And One Transmit Data Signal.
    The Clock Can Be Free Running, So You Can Generate It Quite Easily.
    With Counter.
    The Data Will Be Shift Out When Writing, And In When Reading.
    You Should Use 2 Registers 1 For Write 1 For Read, You Should Also Use
    Address Register, To Access Devices With More Then 1 Internal Address.
    To Select Between Deices You Need Different CS~. You Can Generate Those With Decoder.
    It Will Be Most Easy To Realise The Design With A State Machine, Who Shell Do Or Control All This Tasks.
    •   Alt8th September 2005, 12:48
      advertising
  5. #5
    Full Member level 3
    Points: 2,002, Level: 10
    Join Date
    Jul 2004
    Posts
    172
    Points
    2,002
    Level
    10
    vhdl spi slave
  6. #6
    Full Member level 2
    Points: 2,656, Level: 12
    Join Date
    Feb 2002
    Posts
    121
    Points
    2,656
    Level
    12
    spi vhdl code
    Look at www.Xilinx.com they have a SPI reference design for their CPLDs in VHDL:
    http://www.xilinx.com/products/silic...ce_designs.htm
  7. #7
    Banned
    Points: 1,982, Level: 10
    Join Date
    Aug 2005
    India
    Posts
    147
    Points
    1,982
    Level
    10
    vhdl spi interface
    Hi
    SPI is very very simple serial protocol. You can write your own VHDL program and it doesn't have complexity in programming. I think it can be programmed in VHDL easily rather than Verilog.
    Try to assume the hardware of protocol operation before starting coding. It can be built with simple a shifter and multiplexer/demultiplexer blocks. To send/recieve the data, you can use multiplexer/demultiplexer to select a perticular bit of data.
    I don't think the ready to use IP can fit to your application. Try your own.
    Regards
    Vishwa
  8. #8
    Full Member level 4
    Points: 2,409, Level: 11
    Join Date
    Sep 2003
    Posts
    194
    Points
    2,409
    Level
    11
    spi in vhdl
    See the SPI spec, and there are many implementations in there.
    •   Alt22nd September 2005, 06:39
      advertising
  9. #9
    Member level 3
    Points: 1,648, Level: 9
    Join Date
    Jan 2006
    Posts
    58
    Points
    1,648
    Level
    9
    vhdl spi master
    Can anyone suggest a good book on SPI interface ??
  10. #10
    Member level 3
    Points: 1,981, Level: 10
    Join Date
    Oct 2004
    Posts
    59
    Points
    1,981
    Level
    10
    spi verilog
    You can search xilinx IP core library on the web... there are some freeware vhdl cores... inclusive SPI.
    •   Alt26th February 2007, 12:57
      advertising
  11. #11
    Junior Member level 3
    Points: 1,205, Level: 7
    Join Date
    Feb 2007
    Posts
    26
    Points
    1,205
    Level
    7
    spi controller vhdl
    at ymq8328:
    you still searching a VHDL code of SPI ? If you want send me a private message, I send you my version on SPI (wrote in VHDL).
    Regards
    Lukee
  12. #12
    Points: 12,086, Level: 26
    Join Date
    May 2001
    Posts
    1,126
    Points
    12,086
    Level
    26
  13. #13
    Full Member level 1
    Points: 1,914, Level: 10
    Achievements:
    7 years registered
    Join Date
    May 2006
    Banaglore
    Posts
    95
    Points
    1,914
    Level
    10
    spi master vhdl
    just go through SPI spec....if you need code u can have it from opencores.org
  14. #14
    Newbie level 3
    Points: 970, Level: 7
    Join Date
    Jul 2007
    Posts
    Points
    970
    Level
    7
    vhdl spi core
    can sombody help mee with the VHD code to connect SPI, i whant it to pleas
    thanks
  15. #15
    Full Member level 5
    Points: 4,307, Level: 15
    Join Date
    Dec 2004
    Naboo
    Posts
    270
    Points
    4,307
    Level
    15
    verilog spi master
    Currently, I'm designing a simple SPI. It consist of 1-master and 1-slave. Plus, this is my first time designing SPI.
    I find shawndaking reply is helpful and he is right.
    I gathered a lot of information on internet.
    Another thing, timing diagram is also important. Use Google you can find one.
    That's how I start to understand and design SPI.
    FYI, I used verilog for my SPI.
    Good luck!
  16. #16
    Member level 1
    Points: 1,760, Level: 9
    Join Date
    Dec 2004
    Shanghai, China
    Posts
    41
    Points
    1,760
    Level
    9
    vhdl for spi
    SPI3 is a simple one.
    But SPI4.2 is so complexed and difficult
  17. #17
    Newbie level 3
    Join Date
    Jul 2007
    Posts
    Points
    970
    Level
    7
    spi+vhdl
    what are the difference between SPI3 and SPI4.2? im am just using FPI with 4 wire SDI, SDO SCK and AC.
  18. #18
    Newbie level 1
    Points: 1,049, Level: 7
    Join Date
    Jan 2008
    Posts
    Points
    1,049
    Level
    7
    spi interface cpld
    can anyone send a spi slave vhdl code? i am using altera fpga.
    Thanks,
    Reddy
    •   Alt18th January 2008, 15:33
      advertising
  19. #19
    Newbie level 5
    Points: 900, Level: 6
    Join Date
    Jan 2008
    Posts
    8
    Points
    900
    Level
    vhdl spi
    Can anybody give me a very simple spi implementation in vhdl.
    I found one at fpga4fun.com but it is in verilog,
    something like this what i need, but in vhdl, can anybody help me with a code or with a translating.
    http://www.fpga4fun.com/SPI2.html
    my project:
    i need a communication between Pic18f and fpga, the fpga is the slave.I need it for this. thanks in advance.
  20. #20
    Newbie level 5
    Join Date
    Jan 2008
    Posts
    8
    Points
    900
    Level
    verilog spi
    Does anybody have a simple spi interface written in vhdl.
    Something like when the fpga is the slave and receiving - transmitting data to the Master. The Master is a PIC microcontroller.
    What about the clocks frecvencies???? the pic clock(and the spi clock) is much slower than tha fpga's clock. But i think when the fpga is the slave this is a good version.
    let me know if it's not correct.
