Reading internal signals through a testbench.
dBUGGER
Milky Way
ieee explore
Hi all,
Through a testbench (Verilog or VHDL), how do I read the values of signals of a sub module through a top module? This is required to match and assert if the program is working correctly. Please help. Thank you.
Best Regards,
edaboard
In Verilog testbench its very simple you can refer to submodule signal as follows..
top.sub_module.sub_sub_module.my_signal
Here . is used to seperate the hirarchy!
In vhdl I think you need to use FLI !!!
