Where can I find the datasheet for A1154 PNP transistor?
bigjoe
Member level 2
Does anybody here knows where can I find the datasheet for the a1154 pnp transistor?
regards,
bigjoe
Re: A1154 PNP transistor
I want to ask, is this the complete device name of the transistor? and also, do you know the manufacturer?
Master,
Don't know the name of the manufacturer, this is exactly what is written on the the transistor:
A1154
K21ZA
I think it is from toshiba but I am not sure. Thanks
regards,
bigjoe
Because of operator error, this may be a duplicate post. I apologize if it is.
Try https://www.datasheetarchive.com. They have individual data sheets, as well as data books.
Regards,
Kral
You should search for 2SA1154 in the above link. It is there. I found next data:
2SA1154
TRANSISTOR GENERAL PURPOSE
Material : Silicon
Polarity : PNP
VCBO(max) Collector-to-base voltage, dc, emitter open : 60V
VCEO(max) Collector-to-emitter voltage, dc, with base open : 60V
VEBO(max) Emitter-to-base voltage, dc, collector open : 5V
IC(max) Current, dc (collector-terminal) : 700mA
Power(max) Power dissipation : 1W
hFE(typ) Static forward current transfer ratio (common-emitter) : 200
Pins : 1=E, 2=C, 3=B
guys,
thanks for the replies,
regards to all
