+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Full Member level 5
    Points: 3,445, Level: 13
    Join Date
    Apr 2005
    27.45N, 85.20E KTM, NP
    Posts
    265
    Points
    3,445
    Level
    13
    What is the advantage of using open collector output stage in TTL circuits?
    What is the advantage of using open collector output stage in TTL ckts?
    Magnetra
    •   Alt24th August 2005, 11:30
      advertising
  2. #2
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    Re: Open Collector
    The main advantage of using OC outputs is that the loads's supply voltage can be much higher than 5V; in some cases the OC transistors are rated for 30Vdc or more.
    Also, TTL OC transistors can sink currents of up to 100mA ..
    Regards,
    IanP
    •   Alt24th August 2005, 11:45
      advertising
  3. #3
    Advanced Member level 1
    Points: 4,896, Level: 16
    Join Date
    Jan 2005
    Posts
    432
    Points
    4,896
    Level
    16
    Re: Open Collector
    I think IanP is refering to an open-collector buffer/driver, for example 7406 with maximum VOH up to 30V and maximum IOL up to 40mA, thus the output load (for example an incandescent lamp or car signalling indicator used in automobile of 24V, 25mA.
    VOH = Logic High or 1 Output Voltage
    IOL = Logic Low or 0 Output Current (refers to sink current of the transistor when it is turned on, resulting logic low or 0)
    In general, open-collector is used in the followings:
    1. It can be used with a pull-up resistor Rp of about 1k to 10k for Wired-AND operation, whereby several open-collector outputs can be tied together to the same pull-up resistor Rp for driving logic 1 and 0.
    However, in consideration of the load capacitance in the interconnects and transistors, Rp cannot be too large, else the switching speed is limited due to RC delay.
    Rp cannot be too small because the this will increase the sink current from supply rail down through Rp and the transistor (that is turned on), thus too large current can kill the transistor.
    So Rp should be carefully chosen so that IOL (max) is not exceeded and Rp is not too large that will make RC delay too long.
    2. In some special applications whereby logic 1 or High is not needed, Rp is not used, thus high impedance output or logic 0 is required. This is used for example in the above incandescent lamp, which itself presents a load resistance, thus serving the purpose of Rp in the application. Thus the application does not require to add a pull-up resistor Rp.
    •   Alt24th August 2005, 12:51
      advertising
  4. #4
    Advanced Member level 3
    Points: 7,253, Level: 20
    checkmate's Avatar
    Join Date
    Feb 2004
    Toilet Seat
    Posts
    833
    Points
    7,253
    Level
    20
    Re: Open Collector
    Similar to what the others have mentioned, open collector (or open-drain outputs for CMOS) are used for level-conversion and/or wired-AND. An example of the first feature is when you want to interface 5V to 3.3V circuits, or if you want to drive circuits with a high Vcc. The second application is used in shared buses, where there are multiple bus drivers.
    As for the pull-up resistor used, as SkyHigh has mentioned, it should not be too small as to sink dangerous currents into the output transistor of the chip, and it should not be too large as to cause significant RC delays. For data outputs, this is manifested in the form of slew edges.
  5. #5
    Full Member level 4
    Points: 2,883, Level: 12
    Join Date
    Jul 2004
    Posts
    218
    Points
    2,883
    Level
    12
    Re: Open Collector
    Hi~~
    I have one thing to mention about open collector and open drain circuits. An output circuit of a chip requires a large power consumption compared to the internal logic. Thus, when a designer does not want to consume a large amount of energy, i.e., heat, in his or her device for some reason, he or she will adopt the open collector or open drain circuit as the output circuit.
    •   Alt27th August 2005, 13:03
      advertising
  6. #6
    Points: 17,526, Level: 32
    Join Date
    Oct 2005
    India
    Posts
    1,804
    Points
    17,526
    Level
    32
    Re: Open Collector
    I think the main reason is the amount of current the open collector can source and the output voltage that can be reached...
  7. #7
    Full Member level 5
    Points: 3,353, Level: 13
    dipal_z's Avatar
    Join Date
    Apr 2005
    India
    Posts
    278
    Points
    3,353
    Level
    13
    Open Collector
    A very good application of wired-AND configuration is I2C bus, refer to the following document and you will understand how open collector outputs can help.
    http://www.semiconductors.philips.co...8/39340011.pdf
