+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Newbie level 6
    Points: 1,824, Level: 9
    Join Date
    Dec 2002
    Posts
    13
    Points
    1,824
    Level
    9
    a1018 at commands
    Hi all,
    i want to send and receive SMS, but want to control mobilephones via a pc-rs232 ports or microcontroller.
    so , i need any information,ebooks or links about this.
    thanks !!! :D
    •   Alt24th January 2003, 16:17
      advertising
  2. #2
    Full Member level 5
    Points: 5,001, Level: 16
    tanveerriaz's Avatar
    Join Date
    May 2001
    Pakistan
    Posts
    287
    Points
    5,001
    Level
    16
    nokia rs232 port
    use Logomanager for nokia and sample cable m2bus.
    •   Alt25th January 2003, 01:41
      advertising
  3. #3
    Full Member level 2
    Points: 3,327, Level: 13
    Join Date
    Jan 2000
    Poland
    Posts
    125
    Points
    3,327
    Level
    13
    Some GSM specs about sms.
    arturt134
    •   Alt27th January 2003, 07:15
      advertising
  4. #4
    Member level 2
    Points: 2,636, Level: 11
    Join Date
    Aug 2001
    Posts
    44
    Points
    2,636
    Level
    11
    You should use AT command set used for modems. Search for AT command set for GSM with google, etc. I think sending SMS is quite complicated. :?
    Try this:
    http://www.riccibitti.com/tinyplanet/tiny_intro.htm
    or AT modem standarts for mobiles
    http://webapp.etsi.org (you have to register to download)
    Other important point is the connector. Sometimes it is hard to find a cable and connector for computer communication. I have used ericsson chatboard socket for old models with max232 level converter. :lol:
  5. #5
    Member level 1
    Points: 2,732, Level: 12
    Join Date
    Apr 2002
    Posts
    34
    Points
    2,732
    Level
    12
    Try this:
    •   Alt4th February 2003, 10:13
      advertising
  6. #6
    Advanced Member level 3
    Points: 9,210, Level: 22
    cyberrat's Avatar
    Join Date
    Jun 2001
    In the sewers of the U.K.
    Posts
    858
    Points
    9,210
    Level
    22
    Try mobile.box.sk
    I got a program from there that should allow me to send SMS from my Ericsson.
    Once I make the correct cable.
    There are plenty of programs out there to let you do a lot with your phone.
    Please do not PM me questions that are better asked in the PCB forum :)
  7. #7
    Newbie level 3
    Points: 1,501, Level: 8
    Join Date
    Sep 2004
    romania
    Posts
    Points
    1,501
    Level
    8
    Re: controlling ericsonn/nokia mobiles via pc rs232 port
    it is quite simple:
    you have the at command and with an old erricson a1018 for example you send the AT commands that simulates the pressing of a key. i have done it you cand do it too. i put a program for AT89C2051 that sends a memorated message
  8. #8
    Points: 15,991, Level: 30
    Join Date
    Mar 2002
    Posts
    1,309
    Points
    15,991
    Level
    30
    Quote Originally Posted by oltean
    it is quite simple:
    Again, the topic you are replying to is 1½ year old, there's no reason to answer such old topic, he have probably found a soloution by now since he haven't posted again.
