Zeros at Z=0 in Discrete time filter
hebu
Full Member level 4
What's the characteristic of this kind filter?
And is it reasonable to make a filter like this?
Thanks,
zero means the ascending of the spectrum from the zero to inifinty.
So if you add a zeros at zeros ,that means you want to emphasis the part of the high frequancy band part of the signal.
Can we design a low pass filter with zeros at Z=0?
Thank you,
Of course,you can add all zeros in your design .
Because zeros can't cause the stability problem.
what type of filter u r talking abt? I mean IIR or FIR
thnx
purna
I designed the switched-capacitor filter to implement the
Z-domain transfer function.
