+ Post New Thread
Results 1 to 15 of 15
  1. #1
    Advanced Member level 2
    Points: 4,902, Level: 16
    Join Date
    Jun 2005
    Posts
    599
    Points
    4,902
    Level
    16
    sine wave input to a flip flop
    How do i Divide the Frequency?
    If i take my function generator output 1K hz what circuit can i build to divide this frequency down or UP?
    Oscillators frequencys outputs 440hz how do i divide the oscillators frequency down or UP?
  2. #2
    Advanced Member level 5
    Points: 36,491, Level: 46
    flatulent's Avatar
    Join Date
    Jul 2002
    Middle Earth
    Posts
    4,629
    Points
    36,491
    Level
    46
    convert sine wave to cml
    You can divide using a digital counter type circuit. You can multiply by using a PLL with a divider in the feedback loop.
    •   Alt12th August 2005, 01:47
      advertising
  3. #3
    Points: 32,456, Level: 44
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    dividing sine wave frequency
    Another possible method is to use a band-pass filter to extract one harmonic of your input signal. For example, if your input is a 1 kHz square wave, a 3 kHz band-pass filter would pass only the third harmonic, giving you a 3 kHz sinewave.
  4. #4
    Join Date
    Jun 2005
    Posts
    599
    Points
    4,902
    Level
    16
    cml divider square wave input
    Yes i want to use Sine Wave inputs that divide the Sine wave frequency
    what circuit would do this?
    To divide the Frequency of Sine Waves?
    Are Oscillators Frequencys Sine waves?
    How do divide the oscillators sine wave frequencys?
  5. #5
    Member level 2
    Points: 1,923, Level: 10
    Join Date
    May 2005
    Yk ID
    Posts
    46
    Points
    1,923
    Level
    10
    analog frequency dividers
    well a picture worth thousand words
    it's a divider design which is pretty self-explanatory. One can choose between division by 1, 10 or 100 or no output (tied low) using the CONTROL input connected to the analog multiplexer HC4052. AC04are used to drive 3 indication LEDs as well as to buffer the signal. A single HC390 includes 2 divider by 2 and 5 which can be combined as 2 dividers by 10.
  6. #6
    Join Date
    Jun 2005
    Posts
    599
    Points
    4,902
    Level
    16
    Re: Analog Frequency Dividers
    Is that circuit mostly for Square waves only or pwm wave forums ?
    Or can i use a Sine Wave input also? will it divide the sine wave?
    •   Alt12th August 2005, 05:04
      advertising
  7. #7
    Full Member level 4
    Points: 3,814, Level: 14
    hmsheng's Avatar
    Join Date
    Dec 2003
    China
    Posts
    219
    Points
    3,814
    Level
    14
    Two ways:
    1. You can use CML circuit to divide sine wave signal.
    2. Reshape sine wave signal to square wave then divide it with digital counters.
    •   Alt12th August 2005, 10:05
      advertising
  8. #8
    Join Date
    Jun 2005
    Posts
    599
    Points
    4,902
    Level
    16
    Whats a CML circuit?
    What is CML mean?
  9. #9
    Full Member level 4
    hmsheng's Avatar
    Join Date
    Dec 2003
    China
    Posts
    219
    Points
    3,814
    Level
    14
    CML means Current Mode Logic. It can divide sine wave signal.
  10. #10
    Full Member level 4
    Points: 2,398, Level: 11
    dingjingfeng's Avatar
    Join Date
    Aug 2005
    Posts
    190
    Points
    2,398
    Level
    11
    usually a high divide-by-two circuit is in CML logic
    the basic cell is TFF(toggke flip-flop)
    there are many paper in IEEE in this topic
    the highest CML frequency divider already reach +100GHz
  11. #11
    Junior Member level 3
    Points: 2,002, Level: 10
    Join Date
    Dec 2004
    Posts
    26
    Points
    2,002
    Level
    10
    If no cost consideration, any of the following is an option:
    1.CML circuit;
    2.convert sine wave to squarewave, then divided digitally, then convert the square wave back to sine wave;
    3.use a PLL;
    •   Alt16th August 2005, 04:04
      advertising
  12. #12
    Join Date
    Jun 2005
    Posts
    599
    Points
    4,902
    Level
    16
    How do i put a Sine wave 1Khz input in a PLL circuit with a output thats half the
    frequency?
    How do i put a Sine wave 1Khz input in a CML circuit with a output thats half the
    frequency?
    I'm new to this PLL and CML circuit never worked or built them how do i start this
    are PLL and CML in a Digital circuit book because i can't find any PLL or CML circuit in any of my analog or digiatl books where do i start please?
  13. #13
    Full Member level 4
    hmsheng's Avatar
    Join Date
    Dec 2003
    China
    Posts
    219
    Points
    3,814
    Level
    14
    Quote Originally Posted by walters
    frequency?
    frequency?
    1. You can't get divided frequency signal at PLL output! You can only get multiple frequency of the input frequency, Fout=N*Fin.
    2. Input 1KHz sine wave to CML DFF, output 0.5KHz sine wave.
    3. Search CML DFF on internet!
  14. #14
    Join Date
    Jun 2005
    Posts
    599
    Points
    4,902
    Level
    16
    How does the PLL circuit Divide the frequency Digitally or analog ?
    Whats kind of PLL circuit does this?
    How does the CML circuit Divide the frequency Digitally or analog ?
    Whats kind of CML circuit does this?
  15. #15
    Join Date
    Jun 2005
    Posts
    599
    Points
    4,902
    Level
    16
    A flip flop (bistable multivibrator) divides by two, and was commonly used in old electronic organs.
    Block diagram:
    Sine wave>>>Flip flop>>>divides the freq down>>>Square wave output
    Most of the Flip flops in my digital book are just switching flip flops i don't
    see any Frequency based flip flops
    So i put a sine wave in the input of a flip flop and the output of the flip flop with be a Square wave but half of the freqency of the inputs freqency
    HOW do i set the Flip flops resistors or capacitors to a FIX Frequency to?
    What sets the Flip Flops Freqency?
    What sets the Flip Flop to Divided?
