How autocorrelation is related to psd and fourier transform?
iTdl
Member level 3
autocorrelation
How autocorrelation is related to psd and fourier transform of signal?
Re: autocorrelation
hi
PSD(f)=4*Integral[cos(2*pi*f*t)*Autocorrelation from -inf, +inf]
The PSD is the Fourier transform of the autocorrelation sequence.
hope it helped u
-helios
Re: autocorrelation
FT of the ACF of x(t) is the PSD.
PSD = |FT [x(t)]|^2;
so FT of ACF is |FT[x(t)]|^2;
hope u got it
purna
Re: autocorrelation
ok i am assuming that you are totally new to dsp and as such those two answers that you have already received probably mean nothing to you. Anyway the only relation that there is between autocorrelation and the fourier transfrom is actually the similarity between the DFT (discrete fourier transform) and auto correlation i.e. if you are learning DSP in your book it will give you a hand method of calculating the DFT, cross correlation (between two signals) and the autocorrelation. the calculation of these three items by hand is quite similar (and no i won't get into the technical details for now). the only relation between autocorrelation and psd is the fact that if you take a signal and get the autocorrelation of that signal, then if you apply the fourier transform to the result you will get the psd.
hope this helps,
sincere regards,
t
autocorrelation
PDS = F(R(x))
F() = Fourier transofrm
R(x) = Autocorrelation function
Thanks
Animesh
Re: autocorrelation
I asked the same question a while ago, but everyone kept giving me mathematical equations, can't anybody give us a paper that describes this physically?:idea:
Re: autocorrelation
Hi azaz104,
I dont know the exact paper which describe the mathematical equation physically, but I am attaching a paper which gives you the usage of above mathematical equation in audio/speech codec applications.
I think this paper helps you to understand it physcially.
Thanks
Animesh
Re: autocorrelation
Hi aza101
yes.
Thanks
Animesh
