+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Points: 1,436, Level: 8
    Join Date
    Feb 2005
    Posts
    Points
    1,436
    Level
    8
    vhdl clock divider
    hai friends
    i am a beginner in ASIC. In VHDL i was able to design divide by 3 or divide by 5 circuits using FSM.is it possible to get an 2/3 divider circuit ??. actually the problem is to get 33.33 MHZ from an 50 MHZ source.
    kindly suggest me some technique to achieve it.
    take care
    bye
    •   Alt24th July 2005, 16:28
      advertising
  2. #2
    Advanced Member level 3
    Points: 9,269, Level: 23
    Join Date
    Jul 2004
    Posts
    892
    Points
    9,269
    Level
    23
    clock divider vhdl
    Use PLL to double the clock frequency. Then divide it by 3.
    •   Alt25th July 2005, 04:44
      advertising
  3. #3
    Full Member level 1
    Points: 2,220, Level: 10
    Join Date
    Apr 2005
    Milky Way
    Posts
    108
    Points
    2,220
    Level
    10
    clk divider vhdl
    Use PLL or DCM's to multiply the clock freq by 2. Then divide by three. But just check out, as i think there is some min i/p limit for the i/p frequency to the DCM's.
    Best Regards,
    •   Alt25th July 2005, 04:46
      advertising
  4. #4
    Join Date
    Jul 2004
    Posts
    892
    Points
    9,269
    Level
    23
    clock divider code verilog
    Here is one solution!
    Hope this helps! Here the divided clock won't have 50% duty cycle!
    SORRY the code here is in Verilog. Hope you can convert it to VHDL
    easily.
    module div_2by3(/*AUTOARG*/
       // Outputs
       clk_2by3,
       // Inputs
       clk, reset_n
       input clk, reset_n;
       output      clk_2by3;
       reg   [1:0]  clk_by3_pos, clk_by3_neg ;
       assign      clk_2by3 = (~clk_by3_neg[0] & clk_by3_pos[0]) | (clk_by3_neg[1] & clk_by3_pos[1]);
       always @(posedge clk or negedge reset_n)
         if (!reset_n)
           clk_by3_pos <= 0;
         else
           if (clk_by3_pos == 2)
             clk_by3_pos <= 0;
           else
             clk_by3_pos <= clk_by3_pos + 1;
       always @(negedge clk or negedge reset_n)
         if (!reset_n)
           clk_by3_neg <= 0;
         else
           if (clk_by3_neg == 2)
             clk_by3_neg <= 0;
           else
             clk_by3_neg <= clk_by3_neg + 1;
    endmodule // div_2by3
  5. #5
    Full Member level 4
    Points: 3,031, Level: 12
    Join Date
    Jun 2005
    Posts
    222
    Points
    3,031
    Level
    12
    verilog clock double
    If u r using FPGA's use DCM's easy and best way
    •   Alt25th July 2005, 11:59
      advertising
  6. #6
    Full Member level 2
    Points: 2,960, Level: 12
    BuBEE's Avatar
    Join Date
    Jul 2005
    Thailand
    Posts
    133
    Points
    2,960
    Level
    12
    clock divider code vhdl
    Quote Originally Posted by eeeraghu
    i agree , It's best way
  7. #7
    Join Date
    Jul 2004
    Posts
    892
    Points
    9,269
    Level
    23
    clk divider 2 vhdl
    here goes the VHDL translation for the same code I posted in Verilog
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_unsigned.all;
    entity clk_div_2by3 is
      port (
        clk      : in  std_logic;
        rst_n    : in  std_logic;
        clk_2by3 : out std_logic);
    end clk_div_2by3;
    architecture clk_div_2by3_arch of clk_div_2by3 is
    signal clk_div_by3_pos : std_logic_vector(1 downto 0);
    signal clk_div_by3_neg : std_logic_vector(1 downto 0);
    begin  -- behavior
    clk_2by3 <= (not clk_div_by3_neg(0) and clk_div_by3_pos(0)) or
                (clk_div_by3_neg(1) and clk_div_by3_pos(1));
    pos_edge: process (clk, rst_n)
    begin  -- process posedge
      if rst_n = '0' then -- asynchronous reset (active low)
        clk_div_by3_pos <= (others => '0');
      elsif clk'event and clk = '1' then -- rising clock edge
        if clk_div_by3_pos = "10" then
        else
          clk_div_by3_pos <= clk_div_by3_pos + 1;
        end if;
      end if;
    end process pos_edge;
    neg_edge: process (clk, rst_n)
        clk_div_by3_neg <= (others => '0');
      elsif clk'event and clk = '0' then -- rising clock edge
        if clk_div_by3_neg = "10" then
        else
          clk_div_by3_neg <= clk_div_by3_neg + 1;
        end if;
      end if;
    end process neg_edge;
    end clk_div_2by3_arch;
