tkbits
Full Member level 5
square wave duty cycle
Basic math - a percentage is not a count. It is a fraction. Are you familiar with expressions like 50-50 or 20-80 when people talk about splitting profits? Those are percentages.
Duty cycles are about splitting periodic timing into two parts, the time when the signal is high, and the time when the signal is low. 50% is easy to describe. 50% = 1/2. When you split profits 50-50, each partner gets half the cash. Each of you will get the same amount. Half the time, the signal will be high, and half the time, the signal will be low. You adjust the trimpot until the time (horizontal length) of the high and low signals are equal.
Explaining any other percentage is more time consuming. Good luck on finding someone willing to explain this. You may want to visit a math forum.
