+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 39
  1. #1
    Advanced Member level 2
    Points: 4,902, Level: 16
    Join Date
    Jun 2005
    Posts
    599
    Points
    4,902
    Level
    16
    duty cycle oscilloscope
    When i Display a Period ( one cycle of a waveform ) on the oscilloscope
    how do i get 50% duty cycle?
    The onc cycle takes up the whole screen on the oscilloscope so thats the
    Period of the waveform and how do i get 50% of the duty cycle on the
    oscilloscope?
  2. #2
    Advanced Member level 3
    Points: 7,315, Level: 20
    Join Date
    Apr 2005
    Posts
    881
    Points
    7,315
    Level
    20
    oscilloscope use: duty cycle
    try changing the time /div switch.
  3. #3
    Join Date
    Jun 2005
    Posts
    599
    Points
    4,902
    Level
    16
    measure duty cycle with oscilloscope
    To display the Period in HALF of the oscillscope screen is that what i have to
    do ? to get 50% of the duty cycle of the waveform?
  4. #4
    Advanced Member level 5
    Points: 12,565, Level: 26
    Borber's Avatar
    Join Date
    Jan 2000
    on third flor
    Posts
    1,602
    Points
    12,565
    Level
    26
    oscilloscope duty cycle
    Duty cycle is property of signal and is not depend on oscilloscope settings.
  5. #5
    Join Date
    Jun 2005
    Posts
    599
    Points
    4,902
    Level
    16
    duty cycle in oscilloscope
    If i have a waveforms "Period" display on the oscilloscope how do i get it
    to display 50% duty cycle of a Period?
    Would it be HALF of the display?
    •   Alt24th July 2005, 10:24
      advertising
  6. #6
    Borber's Avatar
    Join Date
    Jan 2000
    on third flor
    Posts
    1,602
    Points
    12,565
    Level
    26
    oscilloscope(duty cycle)
    It would not display 50% duty cycle in most cases. You may set T/div to half the value, if possible, to display half of a periode.
  7. #7
    Join Date
    Jun 2005
    Posts
    599
    Points
    4,902
    Level
    16
    fifty percent duty cycle
    To display 50% duty cycle of a Period on the oscillscope how do i set this up
    or do this?
  8. #8
    Points: 32,456, Level: 44
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    square wave oscilloscope
    "display 50% duty cycle of a Period"
    Your words are nonsense. Please rephrase!
  9. #9
    Full Member level 5
    Points: 3,881, Level: 14
    Join Date
    Aug 2004
    Cyberspace
    Posts
    267
    Points
    3,881
    Level
    14
    duty cycle on oscope
    Maybe have a look here , about the usage of a scope
    http://www.tek.com/Measurement/App_Notes/XYZs/
    /Bingo
  10. #10
    Join Date
    Jun 2005
    Posts
    599
    Points
    4,902
    Level
    16
    square wave 20% duty cycle
    What does 50% duty cycle look like on a square wave on the oscilloscope?
    What does 40% duty cycle look like on a square wave on the oscilloscope?
    What does 30% duty cycle look like on a square wave on the oscilloscope?
    what does 20% duty cycle look like on a square wave on the oscilloscope?
    Is there a duty cycle "Chart" that i could look at?
    •   Alt27th July 2005, 05:59
      advertising
  11. #11
    Borber's Avatar
    Join Date
    Jan 2000
    on third flor
    Posts
    1,602
    Points
    12,565
    Level
    26
    555 50 percent duty cicle
    They all look good.
  12. #12
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    duty cycle on an oscilloscope
    Duty cycle is the percentage of time the pulse is high.
    A square wave, by definition, has 50% duty cycle. If it isn't 50%, then it isn't a square wave.
          _         _
     10% _ _________ _________
          __        __
     20% _  ________  ________
          ___       ___
     30% _   _______   _______
          ____      ____
     40% _    ______    ______
          _____     _____
     50% _     _____     _____   square wave
          ______    ______
     60% _      ____      ____
          _______   _______
     70% _       ___       ___
          ________  ________
     80% _        __        __
          _________ _________
     90% _         _         _
  13. #13
    Points: 7,253, Level: 20
    checkmate's Avatar
    Join Date
    Feb 2004
    Toilet Seat
    Posts
    833
    Points
    7,253
    Level
    20
    how do you find the duty cycle on an oscilloscope
    Similar answer to your other thread. An oscilloscope displays whatever input signal you give it. It does not modify the signal in any way, including its duty cycle.
  14. #14
    Join Date
    Jun 2005
    Posts
    599
    Points
    4,902
    Level
    16
    duty in oscilloscope
    When i hook up a 555 timer clock up to the oscilloscope and i adjust the
    duty cycle trimmer on the 555 timer when it displays on the oscilloscope how
    do i know the square wave is 50% or 70% duty cycle when im turning the
    duty cycle trimmer on the 555 timer to calibrate it to this duty cycle i need
    chart to reference me with the oscilloscope
    Added after 4 hours 47 minutes:
    Thanks Echo47 for the duty cycle chart
    duty cycle form 10%-90% how many oscilloscope divisions/cubes are there
    when the signal or pulse is high for a
    10%?
    20%?
    30%?
    40%?
    etc..
    I just don't know how many oscilloscope divisions/cubes they are for each of
    there duty cycles so i could count the divisions of the high state of the square
    wave signal or pulse and know what duty cycle i am on the oscilloscope
  15. #15
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    oscilloscope and duty cycles
    You sound like a young student. Have you studied Algebra? This is a simple application of ratios and graphs, so you must understand them first.
  16. #16
    checkmate's Avatar
    Join Date
    Feb 2004
    Toilet Seat
    Posts
    833
    Points
    7,253
    Level
    20
    50 dollar oscillascope
    Firstly, go figure out how to operate an oscilloscope.
    Secondly, go read up on the definition of duty cycles.
  17. #17
    Join Date
    Jun 2005
    Posts
    599
    Points
    4,902
    Level
    16
    oscilloscope on time duty cycle of a square wave
    How many division on in a 10% duty cycle?
    how many division on in a 20% duty cycle
    how many division on in a 30%,40,50,60,etc duty cycle?
  18. #18
    Borber's Avatar
    Join Date
    Jan 2000
    on third flor
    Posts
    1,602
    Points
    12,565
    Level
    26
    duty cycle square wave 90 percent
    Are you collecting points this way?
  19. #19
    Join Date
    Jun 2005
    Posts
    599
    Points
    4,902
    Level
    16
    50 percent duty cycle and wave
    Can you please help me figure this out?
  20. #20
    Join Date
    Jun 2005
    Posts
    599
    Points
    4,902
    Level
    16
    definitition of duty cycle
    I put my oscilloscope on the output of my 555 timer circuit i see a square wave
    on my oscilloscope. I adjust the 555 times circuit duty cycle trim pot but how
    do i know what the percent of my duty cycle?
    So when im looking at the oscilloscope i can see 20%,30%,40,50,60,70 etc
    so i can calibrate my 555 timer to a duty cycle ?
    •   Alt29th July 2005, 03:15
      advertising
