+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Full Member level 6
    Points: 3,962, Level: 14
    metal's Avatar
    Join Date
    Dec 2004
    Posts
    364
    Points
    3,962
    Level
    14
    418/433 MHz Transmitter/Receiver Circuits
    Hello
    Can any body help me with crystal based 418/433 MHz schematics that can be easily built, I need them badly.
    Thanks in advance
    •   Alt18th July 2005, 14:44
      advertising
  2. #2
    Advanced Member level 2
    Points: 5,484, Level: 17
    Join Date
    Jun 2005
    Kent, UK
    Posts
    596
    Points
    5,484
    Level
    17
    Re: 418/433 MHz Transmitter/Receiver Circuits
    Google. There ae plenty of designs for crystal controlled FM transmitters for the 430-440MHz amateur radio band on the web. simplest one I'v seen
    You should have a wavemeter to check that the output of your transmitter is clean and will not cause interference to other radio users.
    A frequency counter and a radio scanner would be very usefull.
    There are lots of IC's available such as MAX1470 receiver.
    •   Alt18th July 2005, 21:04
      advertising
  3. #3
    Full Member level 5
    Points: 3,090, Level: 13
    Join Date
    May 2005
    Posts
    287
    Points
    3,090
    Level
    13
    Hi;
    Read texts about communication circuits and design circuit.
