How to generate wire connection report in Orcad?
etrobin
Member level 1
[orcad] wire connect???
Hello all,
I would like to get connections report between parts, e.g.
wire1 u1.1 u2.2 u3.3
==> pin1 of u1, and pin2 of u2, and pin3 of u3 all connect by the same wire "wire1"
How do I get generate such report by orcad???
Than you for reply !!!
regards,
etrobin
Re: [orcad] wire connect???
Try
File -> Export -> Max Ascii netlist
and you will get ascii netlist, i guess that is what you want.
Good luck
Borisov57
