ahmad_abdulghany
- Joined
- Apr 12, 2005
- Messages
- 1,206
- Helped
- 102
- Reputation
- 206
- Reaction score
- 22
- Trophy points
- 1,318
- Location
- San Jose, California, USA
- Activity points
- 11,769
Assalamo alaykom
Can anyone help me to write to the EEPROM of PIC16F84A .. I don't know anything about it.. and i need help to make the following :
- I make a program that receives IR coded serial signal from a remote control.. The code corresponding to each button consists of 42 bits
- I store each entered into six registers ..
- and then decode code at each button pressed
- then store its decoded value in a register ..
- I take four buttons ( digits ) as a secret code ..
- i.e. I compare them into a stored values in four registers called in my program Code_0, Code_1, Code_2, and Code_3 ...
- if entered code was right .. a LED turned ON to indicate that you PASSED after entering the correct code ..
The problem now is :
I want to make the code variable not fixed by changing it externally .. i.e. I want to store the code to be compared into the EEPROM .. and write to it the new code some way ..
Pleeeeeeese help out .. this project must be delivered the day after tomorrow ..
it is urgent !!! .. i finished every thing and it worked alhamdulillah very good but the secret code is fixed not programmable ....
Thank you very much ..
Salamo alaykom
Salamo alaykom
