+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Newbie level 6
    Points: 1,413, Level: 8
    Join Date
    May 2005
    Posts
    11
    Points
    1,413
    Level
    8
    What is the difference between JFET and MOSFET?
    What is the difference between JFET and MOSFET? Which one is better and how?
  2. #2
    Full Member level 6
    Points: 2,793, Level: 12
    Join Date
    Jun 2005
    Posts
    373
    Points
    2,793
    Level
    12
    difference between jfet and mosfet
    JFET use PN junction to provide high input impedance.
    MOSFET use isolated gate to provide high input impedance.
    best regards
    Quote Originally Posted by armohan
    •   Alt30th June 2005, 12:38
      advertising
  3. #3
    Points: 12,011, Level: 26
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    differences between jfet and mosfet
    MOS fets usually have lower gate leakage current. MOS fets are more readily available as high power/high current devices. MOS fets generally have higher forward transconductance (10s of Siemens vs fractions of Siemens). You must be careful not to forward bias the gate-source diode in a JFET. Providing reverse polarity (e.g a negative gate-source voltage on an N channel MOSFET) has no deleterious effect, as long as you stay within the device ratings.
    •   Alt30th June 2005, 16:40
      advertising
  4. #4
    Full Member level 1
    Points: 2,116, Level: 10
    Join Date
    Aug 2004
    Posts
    96
    Points
    2,116
    Level
    10
    mosfet vs jfet
    The main different is that the JFET have a PN juntion for it have high input impedance.
    The MOSFET have isolated gate with polysilicon.
    •   Alt30th June 2005, 16:44
      advertising
  5. #5
    Member level 5
    Points: 2,058, Level: 10
    Join Date
    Apr 2005
    INDIA
    Posts
    93
    Points
    2,058
    Level
    10
    difference between fet and mosfet
    Hi
    There are many differences.
    Biggest one is the topology.
    MOS has higher input impedence.
    JFET has higher current drive (transconductance), lower output impedance and can be used for high drive purposes. There are others also.
    Try to grasp the difference in the functionality of both and they will popup automatically.
  6. #6
    Junior Member level 2
    Points: 1,468, Level: 8
    Join Date
    Jun 2005
    Posts
    22
    Points
    1,468
    Level
    8
    difference between mosfet and jfet
    JFET use PN junction to controll the current ,Mos use isolated gate to controll current. In the ic world now, mos is dominent technology.
  7. #7
    Full Member level 1
    Points: 2,323, Level: 11
    Join Date
    Jul 2004
    Posts
    114
    Points
    2,323
    Level
    11
    jfet and mosfet
    i think this web is hopeful for u:
    http://www.phys.ualberta.ca/~gingric...es/node93.html
  8. #8
    Full Member level 3
    Points: 2,614, Level: 11
    Join Date
    Oct 2004
    Posts
    169
    Points
    2,614
    Level
    11
    jfet mosfet
    JFET is junction field effect transistor.and mosfet is metal semi oxide field effect transistor.i think mosfet is better than FET.
    Added after 1 seconds:
    •   Alt2nd July 2005, 11:24
      advertising
  9. #9
    Member level 1
    Points: 1,523, Level: 8
    Join Date
    May 2005
    Posts
    32
    Points
    1,523
    Level
    8
    jfet vs. mosfet
    There's another difference
    In JFET increasing the gate to source voltage decreasing the source drain current it mean maximum source drain current at Vgs=0 volt
    While at MOSFET increaing the gate voltage results to increasing the source drain current and it's calles enahancment mode
  10. #10
    Points: 1,369, Level: 8
    Join Date
    Jun 2005
    Posts
    Points
    1,369
    Level
    8
    mosfet vs fet
    In MOSFET's the channel is made by the formation of the inversion layer and the charge on the inversion layer is controlled by the gate voltage.
    While in JFET an already opened channel (when no gate voltage is applied) is controlled the formation of the depletion regions on the pn junctions betweengate and the bulk.
    So JFET operates on the formation of the pn junctions while the MOSFET operates on the formation of the inversion layer.
    MOSFET's are better due to the low lekages (greater controllability) and capability of having very high integration.
  11. #11
    Full Member level 1
    Points: 1,856, Level: 10
    Join Date
    Apr 2004
    Posts
    105
    Points
    1,856
    Level
    10
    differences between mosfet and jfet
    maybe you can ref some IC books for detail informations
    Good good study, Day day up!
