+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Points: 1,515, Level: 8
    Join Date
    Oct 2004
    Posts
    Points
    1,515
    Level
    8
    difference of 13.56mhz and 125khz rfid
    hi,
    What is the difference between 13.56 MHz and 125kHz RFID tag?
    Thanks
    •   Alt30th June 2005, 05:36
      advertising
  2. #2
    Member level 4
    Points: 2,293, Level: 11
    Join Date
    Jul 2004
    Posts
    76
    Points
    2,293
    Level
    11
    125khz or 13.56mhz difference
    Well 13.56 MHz are close range tag <10cm or so and always used in smart card, auto immobilizer.. For 125 kHz are use for long range tag (can be detected up to 1 meter). It is used in animal identification and others..
    Regards
    1 members found this post helpful.
  3. #3
    Advanced Member level 3
    Points: 6,562, Level: 19
    pisoiu's Avatar
    Join Date
    Dec 2002
    Romania
    Posts
    750
    Points
    6,562
    Level
    19
    125khz wavelength
    Well, the existance of so many standards make the difference blurry. Both are close range, the vast majority of the readers works up to 10cm, and of course, there are complex readers which are able to read from higher distances. The difference is at the performed functions (besides the operating frequency). Most of the 125khz cards are read only, meaning they have a unique code hardwired, the reader get the code in clear form, and that's all. The 13,56mhz are more complex cards. Some of them have advanced functions like reading/wwriting data, communication using encrypted protocols, etc. They are more suitable for ticketing, secured access, etc. The difference in the operating frequency imposes a difference in the reader construction. For example, the antenna for 125khz reader is made with copper wires, due to the relatively low frequency, but the antenna for 13,56mhz can be made directly on the PCB with traces. Also, you can use the search function: http://www.edaboard.com/viewtopic.ph...ht=pisoiu+rfid
    /pisoiu
  4. #4
    Full Member level 5
    Points: 4,344, Level: 15
    Join Date
    Feb 2005
    North Syracuse, NY
    Posts
    296
    Points
    4,344
    Level
    15
    differences 125khz
    Read distance for both is roughly related to coil size. We all call them "antennas", but they really are not antennas. At those two frequencies, RFID works by inductive coupling, like a transformer. If you have a large read distance (several meters), then at least one of the coils (usually, the reader) is large. Each coil is resonated at the operating frequency with a capacitor. (I think that is the case with 125 kHz, most of my playing has been at 13.56 MHz).
    You get into a real antenna at 900 MHz where the wavelength is a few CM. Now, you can get 10+ meters range with small tags and readers. In all cases, you do run into problems with nearby objects, esp. if made of metal.
    •   Alt30th June 2005, 14:10
      advertising
  5. #5
    pisoiu's Avatar
    Join Date
    Dec 2002
    Romania
    Posts
    750
    Points
    6,562
    Level
    19
    10 meters 13.56 mhz rfid
    Hi James,
    You're absolutely right about the "antennas", I am sorry for the term confusion. As a matter of fact, one such coil I use for 13,56 is made on multilayer PCB and it is shielded on top and bottom layer, so only inductive coupling with it is possible. 125 khz coils works at resonance, as well as 13,56. The main problem which I experienced in the past with ranges over 10cm was an increased performance demand from the analog part, because the modulation level can be quite low compared with the level of the resonant carrier. One other issue which I think it can be a problem (however I don't know if in practice remains true) is the posibility to de-tune the resonant circuit if metalic objects are present nearby the reader coil.
    /pisoiu
    •   Alt30th June 2005, 14:35
      advertising
  6. #6
    Full Member level 5
    Join Date
    Feb 2005
    North Syracuse, NY
    Posts
    296
    Points
    4,344
    Level
    15
    resonant inductive coupling 13.56 mhz
    Hi pisoiu -- Detuning can be a big problem. Apply a tag to a cardboard box, or to a metal barrel, and you get two really different resonant frequencies. In a grocery cart, is the RFID tag sitting next to the metal grill of the cart, or next to a big bottle of soda or 12-pack of beer cans? RFID has a huge potential, but this is one of the downsides that RFID proponents tend to keep silent about. As I have stated in other postings on EDABoard, I think it is very important to point out both weaknesses and strengths. The detuning problem is a weakness. I do have a partial solution for 900 MHz RFID, which I can post if there is interest. For 13.56 MHz, it remains a tough problem.
  7. #7
    Full Member level 5
    Points: 3,276, Level: 13
    Join Date
    Jan 2005
    Asia
    Posts
    311
    Points
    3,276
    Level
    13
    125 khz 13.56 mhz advantages
    hi,
    The two types of tags are very much different. Here i give a easy to read comparision ,please refer to RFID Handbook, or AIMS global website for more details.
    ( 125 Khz 13.56 Mhz
    1. Range : Less(few cms) More (around 1 Meter)
    2.Technology: Vicinity coupling Near field coupling
    3.Antenna : Quite large Compact
    4. Use : Limited Wide applications
    5. Cost : Cheaper Some what costlier than 125Khz
    Apart from these there some technical differences like effect of interference etc...but that needs specialised reading.
    ( oops , the message is not displayed quite like i wanted it to be....the spaces are erased ,hence the tabular look is visible no more ,please try to understand it as it is )
  8. #8
    pisoiu's Avatar
    Join Date
    Dec 2002
    Romania
    Posts
    750
    Points
    6,562
    Level
    19
    125khz tag coil
    Quote Originally Posted by rautio
    ... I do have a partial solution for 900 MHz RFID, which I can post if there is interest.....
    Hi James,
    Yes, I think it will be interesting for many, but perhaps it should be done in a new topic. However, one of the advantages of both 125khz and 13,56mhz are the use of passive transponders. Is your 900MHz sollution keeping this advantage? To be sincere, this idea stays from a long time in my memory cells...to insert my bag full of stuff in a coil reader and to see at a display how much do I have to pay, without unloading anything..., but it seem that metallic objects are troublesome..
    /pisoiu
    •   Alt2nd July 2005, 09:47
      advertising
  9. #9
    Member level 4
    Points: 2,228, Level: 10
    Join Date
    Jan 2006
    Posts
    72
    Points
    2,228
    Level
    10
    differances between 125khz rfid and 13.56mhz rfid
    Hi
    1- You can send more data with more speed by 13.56 MHZ tag
    2- Antenna of 13.56 MHZ reader is smaller than 125KHZ
    3- 125 khz is better for the place which is near metal
    However 125khz tag are going to be vanished and discontinued
  10. #10
    Full Member level 3
    Points: 2,395, Level: 11
    Join Date
    Jan 2007
    Planet earth (most of the time)
    Posts
    188
    Points
    2,395
    Level
    11
    rf interference, 900mhz, syracuse ny
    Smart - why do you think that 125KHz tags are going to go away? Do you think that an entire industry and huge deployed base of tags and readers is just going to vanish without a solution? (really, I am not being sarcastic!)
  11. #11
    Member level 5
    Points: 1,722, Level: 9
    Join Date
    Sep 2006
    Posts
    81
    Points
    1,722
    Level
    9
    rfid 125khz 13,56 mhz
    der r rfid uses near metals ..4 which 125khz is d best suited freq range & is d only range suited...so i in any ways dont think dat it is vanishing
  12. #12
    Full Member level 1
    Points: 2,439, Level: 11
    Join Date
    May 2004
    Posts
    117
    Points
    2,439
    Level
    11
    differene between rfid tags and readers
    i need to know what is suitable for a product serialization in a warehouse using RFID tags a and reader ,( 125 Khz , 13.56KHZ , 900 MHZ ).
    the RFID should be relativly cheap and all RFID tags should be read without problems from a range of at least 2 meters
    Pls help
    Kind Regards
