+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Points: 1,374, Level: 8
    Join Date
    Jun 2005
    Posts
    Points
    1,374
    Level
    8
    What is the effect of capacitor put in parallel with the resistor in emisor pin?
    What is the efect of the capacitor put in paralell with the resistor in emisor pin.
  2. #2
    Member level 5
    Points: 2,032, Level: 10
    Join Date
    Jul 2004
    Posts
    80
    Points
    2,032
    Level
    10
    Re: CAPACITOR IN BJT
    Rise the gain of the amplifier, this happen because , the capacitor goes to short circuit in AC and the emisor pin goes to ground and the amplifier become a emisor comun amplifier who has the higest gain.
    •   Alt12th June 2005, 02:34
      advertising
  3. #3
    Full Member level 1
    Points: 2,412, Level: 11
    Join Date
    Sep 2003
    Posts
    98
    Points
    2,412
    Level
    11
    Actually we can 2 things by putting capcitor (CE) parallel with resistor(RE) at emitter.
    Amplifier without RE has more gain as snaider said. (for AC)
    But Amplifier with RE has more stable. (for DC biasing)
    If you want more gain with stable circuit put CE.
  4. #4
    Member level 3
    Points: 2,493, Level: 11
    Join Date
    Dec 2004
    Posts
    62
    Points
    2,493
    Level
    11
    CAPACITOR IN BJT
    fo small signal analysis, the capacitor is considerd to be shorted in AC right? why RE can reduce the Gain? because of feedback?
    •   Alt13th June 2005, 03:26
      advertising
  5. #5
    Full Member level 4
    Points: 3,042, Level: 12
    Join Date
    Feb 2005
    Posts
    196
    Points
    3,042
    Level
    12
    gain (Av) = Vout / Vin
    Av = (Ic.rL) / (Ib.Beta(re'+RE))
    Av = (Beta.Ib.rL) / (Beta.Ib(re'+RE))
    Av = rL / (re' + RE) <-- if the RE increased, the gain reduced
    is it right?? please correct me if it's wrong.
  6. #6
    Member level 2
    Points: 1,648, Level: 9
    Join Date
    Jan 2005
    Posts
    47
    Points
    1,648
    Level
    9
    CAPACITOR IN BJT
    We need to stabilize the Q-point,so,
    we include the RE resistor,
    which is a feedback resistor.
    Let's do the DC analysis of the Common Emitter amplifier:
    Without RE,IC=Beta*IB=Beta*[(VBB-0.7)/RB]
    whose value depend on Beta,which is a variant parameter;
    With RE,IC=Beta*IB
    =Beta*[(VBB-0.7)/(RB+Beta*RE)]
    =Beta*[(VBB-0.7)/Beta*RE]
    =(VBB-0.7)/RE
    it's a fixed value.
    O.K. we get DC Q-point stabilization now,
    how about the ac gain?
    Do the ac analysis:
    Without RE:
    A=-ic*RC=-Beta*ib*RC
    =-Beta*[(1/(RB+r-phi)]*RC
    =-Beta*[1/RB]*RC
    =-Beta*(RC/RB) --->a large value
    With RE:
    =-Beta*[1/(r-phi+Beta*RE)]*RC
    =-Beta*[1/Beta*RE]*RC
    =-RC/RE
    =-1*(RC/RE)---------> a smaller value
    yean,
    with RE ,we get stabilization but we lose ac gain.
    How to improve ?
    If we connect a capacitor CE across the RE.
    At DC analysis,the CE will be open circuit.
    we still get the stabilization.
    At AC analysis,the CE will be short circuit and
    "short out" RE (Bypass)
    we get the ac gain.
  7. #7
    Newbie level 6
    Points: 2,020, Level: 10
    Join Date
    May 2005
    Posts
    12
    Points
    2,020
    Level
    10
    The purpose of the amplifier is get maximum output signal (a.c.) from the input at the same time we need to make Q-point stable so that it doesn't happen that on side (day +ive) our signal gets amplified but on the other side it gets chopped due to improper location of Q-point. Q-point is dependant upon how the circuit is baised. The resistor at Emitter plays a major role in circuit biasing and Q-point stabilization but this resistor would also reduce the gain of the amplifier so, which isnot desirable. Thus we put a capacitor in parallel with the resistor. Now for DC capacitor virtually acts as an open circuit hence no effect on Q-point stabilization. For AC it essentially acts as a short circuit nullifying the effect of parallel resistor this resulting in maximum gain.
    •   Alt13th June 2005, 20:55
      advertising
  8. #8
    Member level 4
    Points: 2,293, Level: 11
    Join Date
    Jul 2004
    Posts
    76
    Points
    2,293
    Level
    11
    hi,
    Thanks for those info ed_surfer. How do we determine the value of the capacitor parallel to RE. Is there any formula/equation related to it?? Thanks
  9. #9
    Full Member level 3
    Points: 2,614, Level: 11
    Join Date
    Oct 2004
    Posts
    169
    Points
    2,614
    Level
    11
    The reason for this is-
    1>for a.c it acts like a short ckt so it behaves as a.c ground
    2> for d.c it acts as open circuit.d.c biasing is un disturbed.
  10. #10
    Full Member level 6
    Points: 2,793, Level: 12
    Join Date
    Jun 2005
    Posts
    373
    Points
    2,793
    Level
    12
    It can increase high frequency gain.
    best regards
    Quote Originally Posted by fab
