High speed ADC in DIP package with up to 20 MSPS sampling rate
chupos
Member level 1
Hi, basically I need a high speed ADC, up to 20 MSPS, but in DIP package ><.
didn't find anything beyond 2 MSPS in DIP package, anyone knows any ADC in DIP package with up to 20 MSPS sampling rate?
Another point is... would a PICmicro or dsPIC be able to handle this rate? anyways this isn't the main point of my question :)
thanks in advance,
alex
adc msps dip
20MSPS ADC usually comes in SMT package. You can design a SMT-> THT converter or adaptor.
adc 20msps dip
What you need DIP packages for? Are you thinking in placing a 20MSPS ADC into a solderless prototype board? I´ll get messy.
dsPIC reach up to 30 MIPS so... basically you will not be able to handle 20MSPS
adc 20 msps dip
I mainly need DIP... for these reasons:
- prototyping with SMT ... sucks!
- soldering SMT ... sucks!
- rest of the board would probably be DIP
but anyways, if there's no other way, I would use a SMT ADC...
ehm, so about dsPIC... so whats about the maximum speed I can get with it? (sampling speed of an external ADC)
and, is there any other cheap DSP or MCU that would be able to handle it? should be easy to program, and be kinda at least somewhat popular, so there's enough information on it.
Maybe FPGAs and/or CPLDs would be a solution, but they are too expensive, especially to program.
Thanks for the info,
Alex
adc 10 mhz dip
If you are sampling a repetitive signal, you may not need 20 MSPS to get 10 MHz bandwidth.
If you want to stick with DIP and PIC you can't handle 20 MSPS but if you use an equivalent sampling technique you don't have to sample that fast to capture a repetitive signal and could still use a slower DIP ADC and a PIC.
Re: High Speed ADC
With such high speed sample rate, DIP package is rare,
you can try a soic package, the performance will be better
than DIP for its low parasitic inductance.
best regards
thanks in advance,
alex
