+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Advanced Member level 1
    Points: 4,947, Level: 16
    Join Date
    May 2004
    oriental
    Posts
    494
    Points
    4,947
    Level
    16
    barrel shifter verilog
    Hi all,
    How to write a barrel shifter in Verilog?
    Any easy approaches will be appreciated!
    Best regards,
    Davy
    •   Alt8th June 2005, 04:22
      advertising
  2. #2
    Advanced Member level 3
    Points: 9,432, Level: 23
    Join Date
    Jul 2004
    Posts
    892
    Points
    9,432
    Level
    23
    verilog barrel shifter
    You can refer to following sample chapter from "Digital Design Principles and Practices "
    by John F. Wakerly
    www.ddpp.com/DDPP3_mkt/c06samp1.pdf
    You try to describe it in verilog. If you face in difficulty let us know!
    We will do it for you!! But its better you try first writing the code!
    Hope this helps!
    •   Alt8th June 2005, 05:35
      advertising
  3. #3
    Member level 5
    Points: 1,978, Level: 10
    Join Date
    May 2004
    Posts
    94
    Points
    1,978
    Level
    10
    barrel shifter vhdl
    use case to synthesize a multipler. But it seems transistor array cannot be synthesized unless you use self-designed cells or plot the schematic and design it using analog method.
    1 members found this post helpful.
    •   Alt8th June 2005, 05:37
      advertising
  4. #4
    Join Date
    Jul 2004
    Posts
    892
    Points
    9,432
    Level
    23
    vhdl barrel shifter
    You can get good example of Barrel Shifter in nnArm core code!
    Hope this helps!
  5. #5
    Junior Member level 1
    Points: 1,671, Level: 9
    Join Date
    Mar 2004
    Posts
    15
    Points
    1,671
    Level
    9
    barrel shifter vhdl or verilog
    hi
    simple code for barrel shifter is given in VHDL primer J. Bhaskar book but it is in VHDL . I think its logic can easily be converted to Verilog code
    bye
    •   Alt8th June 2005, 15:11
      advertising
  6. #6
    Points: 1,164, Level: 7
    Join Date
    Sep 2006
    Posts
    7
    Points
    1,164
    Level
    7
    barrel shifter design
    module shifter_main(Q,A,C0,C1,C2,Cin,Cout);
    input [7:0] A;
    input C0,C1,C2,Cin;
    output [7:0] Q;
    output Cout;
    reg [1:0]S;
    always @ (C0 or C1 or C2)
    if(C0) S=2'b00;
    else if(C1) S=2'b01;
    else if(C2) S=2'b10;
    else S=2'b11;
    shifter cct(Q,S,A,Cin,Cout);
    end module
    module Barrel_shifter_main(A,C0,C1,C2,C3,Q);
    input [7:0]A;
    input C0,C1,C2,C3;
    output [7:0]Q;
    reg [2:0]S;
    always @ (C0 or C1 or C2 or C3)
    if(C0) S=3'b001;
    else if(C1) S=3'b011;
    else if(C2) S=3'b101;
    else if(C3) S=3'b111;
    else S=3'b000;
    barrel_shifter shfter(A,S,Q);
    end module
    The code for the 4x1 MUX used in the Shifter;
    module mux(y,d0,d1,d2,d3,s);
    input d3,d2,d1,d0;
    input [1:0]s;
    output y;
    reg y;
    always @ (d0 or d1 or d2 or d3 or s)
    case (s)
    2'b00:y=d0;
    2'b01:y=d1;
    2'b10:y=d2;
    2'b11:y=d3;
    endcase
    end module
    module mux8x1(y,d0,d1,d2,d3,d4,d5,d6,d7,s);
    input d0,d1,d2,d3,d4,d5,d6,d7;
    input [2:0] s;
    output y;
    reg y;
    always @(d0 or d1 or d2 or d3 or d4 or d5 or d6 or d7 or s)
    case (s)
    3'b000:y=d0;
    3'b001:y=d1;
    3'b010:y=d2;
    3'b011:y=d3;
    3'b100:y=d4;
    3'b101:y=d5;
    3'b110:y=d6;
    3'b111:y=d7;
    endcase
    end module
    module shifter(Q,S,A,Cin,Cout);
    input [7:0] A;
    input [1:0]S;
    input Cin;
    output [7:0] Q;
    output Cout;
    parameter d=1'b0;
    reg Cout;
    mux mux1(Q[7],A[7],Cin,A[6],d,S);
    mux mux2(Q[6],A[6],A[7],A[5],d,S);
    mux mux3(Q[5],A[5],A[6],A[4],d,S);
    mux mux4(Q[4],A[4],A[5],A[3],d,S);
    mux mux5(Q[3],A[3],A[4],A[2],d,S);
    mux mux6(Q[2],A[2],A[3],A[1],d,S);
    mux mux7(Q[1],A[1],A[2],A[0],d,S);
    mux mux8(Q[0],A[0],A[1],Cin,d,S);
    always @ (A or S)
    case (S)
    2'b00: Cout=0;
    2'b01: Cout=A[0];
    2'b10: Cout=A[7];
    2'b11: Cout=0;
    endcase
    endmodule
    //The code for the rotator;
    module barrel_shifter(A,S,Q);
    input [7:0]A;
    input [2:0]S;
    output [7:0]Q;
    parameter d=1'b0;
    mux8x1 mux0(Q[7],d,A[6],A[5],A[4],A[3],A[2],A[1],A[0],S);
    mux8x1 mux1(Q[6],d,A[5],A[4],A[3],A[2],A[1],A[0],A[7],S);
    mux8x1 mux2(Q[5],d,A[4],A[3],A[2],A[1],A[0],A[7],A[6],S);
    mux8x1 mux3(Q[4],d,A[3],A[2],A[1],A[0],A[7],A[6],A[5],S);
    mux8x1 mux4(Q[3],d,A[2],A[1],A[0],A[7],A[6],A[5],A[4],S);
    mux8x1 mux5(Q[2],d,A[1],A[0],A[7],A[6],A[5],A[4],A[3],S);
    mux8x1 mux6(Q[1],d,A[0],A[7],A[6],A[5],A[4],A[3],A[2],S);
    mux8x1 mux7(Q[0],d,A[7],A[6],A[5],A[4],A[3],A[2],A[1],S);
    endmodule
    2 members found this post helpful.
  7. #7
    Member level 5
    Points: 1,703, Level: 9
    Join Date
    Dec 2004
    Lebanon
    Posts
    88
    Points
    1,703
    Level
    9
    barrel shifter
    If you are using a Xilinx chip, take a look at this application note from Xilinx :
    Implementing Barrel Shifters Using Multipliers ( available @ http://direct.xilinx.com/bvdocs/appnotes/xapp195.pdf )
    It explains how touse embedded multipliers to design an efficient 32 bit barrel shifter, a sample application in VHDL and verilog is available @ http://direct.xilinx.com/bvdocs/appnotes/xapp195.zip .
    Hople this helped
