Schematics of transducers V to 4-20mA and 4-20mA to V
ZeleC
Full Member level 5
4...20mA circuits???
hello
electronically can anyone give me schematics on the concept of transducers voltage to current and current to voltage
thank you
Re: 4...20mA circuits???
On the V-to (4-20mA) conversion you can find several solutions based on XTR.. IC ( **broken link removed**) or you can use standard current source, such as for example LM304, and build a circuit based on that IC.
At the other end, you don't need anything fancy, just 250Ω termination resistor, and that gives you 1V-5V conversion, and any standard 0-5V A/D converter will do the rest.
Regards,
IanP
