what is the diff between dual port & single port RAM?
abhineet22
bangalore
what is the benefits of using dual port ram?is it only use in fifo ram?
single port memory : has only one data/address port , can either read or write at a time.
dual port memory : has 2 data/address ports , can read and write at same time using both ports.
Re: what is the diff between dual port & single port RAM
DPRAM is widely used for sync,
it is basically a FIFO and SRAM can only act as a RAM
==>l port ram?is it only use in fifo ram?
not exactly
for instance
LCD controller
one port for MCU access
one port for LCD driver access
Hi, whizkid,
I am confused with your answer.
two port memory : has 2 data/address ports , can read and write at same time using both ports. But only one clock.
dual port memory : has 2 data/address ports , can read and write at same time using both ports. Bus two different clocks.
Good Luck
Which types of memory you could use depends on memory compiler your company has (notice that memory compilers are extremelly expencive tools).
Still usage of 1-port memory is the best whenever it is possible, because small arbitration logic is much less costly that memory area increase (it is up to 50% for memories with 1R, 1W port, single clock). Personally I have never seen support for full dual-port memory (2 RD/WR ports on trully asynchronous clocks) - except on FPGA, of course.
One typical usage of 2-port memory (1 RD, 1 WR port) with 2 asynchronous clocks is resynchronization between different clock domains.
Reasons for usage of 2-port memories in real designs are almost infinite, but frequently it is designers lazzyness to do arbitration between different clients even there are enough bandwidth. Somethimes type of design requires lot of dual-port memories, but usually 90+% of memories are 1-port in good designs.
one port has only one core. two port is one core shared by two independent address.
yes, core bit array is shared between two ports.
only sense amplifier and read/write mux is duplicated.
It should be consider to dual port and two port. It is not the same. Their different is one clock or two clocks are used.
two port , read/write can be operate at the same time, one port, read /wrtie operation respestively.
In our memory compiler I find one port , tow port, and dual port . I dont know what means.
the fifo generally use two ports register-file.
it have seperatly write and read ports.
the single ports have a shared R/W ports,
the dual ports have two R/W ports,
each can read/writed.
If you want to implement FIFO by SRAM. You can use two-port SRAM and dual-port SRAM. But I prefer to use two-port SRAM, because the RAM size is smaller than dual-port one.
With dual ram,you have dual bandwidth,so the performance is rised.
hi,
dual port is having two clks.while single port ram having single clk.
with regards,
kul.
DPRAM has an advantage that it can simultaneously read and write on a single clock, and latency is less for a high bandwidth designs. But to the hardware point of view it generates more number of flip flops,
dual port memory : has 2 data/address ports , can read and write at same time using both ports. But two different clocks.
single port ram: ram array can be accessed by one address port;
two port ram: ram array can be accessed by two address port;
