What is a look-up table in relation to FPGA?
icon
Member level 2
india
WHAT IS A LOOK UP TABLE?
WHAT IS THE NEED OF A LOOK TABLE.
HOW LOOK TABLE ARE MADE INSIDE IN CL
regarding FPGA
Hello icon,
LUTs are used to implement combinatorial logic. Most LUTs in FPGA have 4 inputs and one output. So you can design a logic with 16 (2^4) different result.
Look-Up-Tables (LUTs) are described very well in the datasheets of FPGA. Just download one of these from Altera, Xilinx, …
What do you mean with “CL”?
Bye,
cube007
Re: regarding FPGA
its not cl its configarable logic block(clb)
my doubt is 1.whether look up table cannot be used for sequential circuits
2.i didnt get what you mean by 4 inputs (2^4=16) that sentence itself
3.can anyone just simply tell me what is the purpose and why it is used
4.how will we make a look up table
..any simple example...
regarding FPGA
Hello icon,
It’s nice to see you here.
1. That’s right. For sequential circuits you need a register too. Registers are part of LE (Logic Elements, Altera) / CLB (configurable logic block, Xilinx).
2. A LUT with 4 inputs and one output has a depth of 16. For each value of the inputs you get a corresponding output. So the inputs are working like an address for RAM/ROM with a 1 bit width. The content of the LUT will be configured during start-up when using SRAM based FPGA or is burned in OTP (one time programmable) devices.
3. It is used because it is very simply and flexible. Sorry this might be a little less information.
4. You don’t have to care about how to build up a LUT when using FPGAs. All you need is to describe your design with a HDL (hardware descripton language) like VHDL/VERILOG and a synthesizing tool like ISE from Xilinx or Quartus from Altera.
Do you want to use a FPGA in your next project? What’s the task of this project?
Regards,
cube007
Re: regarding FPGA
3. Any Boolean function can be defined with a truth table, and the FPGA lookup table is simply a hardware implementation of a truth table. When you program or configure the FPGA, then for each LUT, you are changing one column of the truth table, the output (or function value).
Re: regarding FPGA
Exactly, that is the missing information in my post. Thanks you tkbits.
Re: regarding FPGA
hi cube007
i am studying FPGA for my next project works.....
can u just explain how to create a lut of a halfadder for example
a b s c
0 0 0 0
0 1 1 0
1 0 1 0
1 1 0 1
i wish to create alut for this how will i create by that statements...oh my head is breaking in this lut....
as u said i am not thinking much more and will write my verilog code and the FPGA will do the rest,,,,,isnt it....
can u just explain how a full adder or multiplexer is implemented in an FPGA.code i know but inside configurable logic block how will it work..
Re: regarding FPGA
Hello icon,
IMHO:
In your example you would need two LUTs because you have two outputs - so one LUT for each Boolean term. Both LUTs are using the same two inputs (a, b) to decode the output.
LUT 1     LUT 2
a b  s    a b  c
0 0  0    0 0  0
0 1  1    0 1  0
1 0  1    1 0  0
1 1  0    1 1  1
It is very possible that there is a more resource optimized solution too.
Bye,
cube007
    icon
