diff between async fifo and sych fifo ram?
abhineet22
bangalore
can any one tell me what is the diff between sychronous fifo and asynchronous fifo ram?
and which is better?
async fifo: control signals can vary at anytime
sync fifo: control ans data signals are sampled by a master clock signal
Usually, synchronous memories speed is higher than async ones.
Which is better? It depends on your application. You have to calculate your requirements, and take a look at your avalilable FIFOs.
i want to comment about "angelote" replay ....
the synchronous memories speed is less than the asynchronous memories,
but the synchronous memories provide less complex structure.
